Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 09-19-2007, 11:54 AM
cyrax122 cyrax122 is offline
code 0422
99.5 jetta 2.0
I have a obdII reader
I read P0422
Main Catalyst,Bank1 Below Threshold
Can any one tell me what that is?
Thank You
Old 10-16-2007, 08:04 PM
2001jettavr6 2001jettavr6 is offline
Re: code 0422
It is either the o2 sensors on the catalytic converter or the catalytic converter itself is bad
Old 03-20-2010, 04:48 PM
warlock40 warlock40 is offline
Re: code 0422
I'm getting the same thing.
If it was a bad O2 sensor would it detect this?
The O2 sensors are ridiculously priced for this car.
So I didn't want to change them just to see if it was the catalytic but then thats not a cheap fix either.
I was looking at these has anyone used this babies.. generic O2 sensors.
http://www.autopartswarehouse.com/sk...etrain#reviews
I'm also looking at a way to test them. .I don't have leads that will connect properly to the pins.. I'm having a hard time getting getting to the pins they are close together and my regular jump connectors are just to big to fit in the connector housing.
I was looking around on the internet and found a o2 bench test for this and I was contemplating taking them out and using this method to test.
http://www.youtube.com/watch?v=vdn4Dk5PSwc
will this really work?
Old 03-23-2010, 10:42 AM
Re: code 0422
Is there a better web place I should be going to ask VW questions like this?
Old 03-23-2010, 11:23 AM
Franco2112 Franco2112 is offline
Re: code 0422
It's the sensors. Get OEM brand for ultimate satisfaction. Here is a link to your problem. You could also try vwvortex.com for more issue solutions like yours. Good luck!
http://wiki.ross-tech.com/wiki/index...22&fulltext=Go
Franco
Old 03-26-2010, 09:20 AM
Re: code 0422
Thanks
I found a supplier in Canada that I can get OEM replacements or the aftermarket version I guess for about $100 cheaper than I can get them at the part source or any retail location Ive found around here.
Im going to pull them this weekend to at least try the bench test that I linked above.. and see how that goes
Ill check out that site as well thanks.
