Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 09-19-2007, 10:32 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
CF Hood Clear coat
I got quoted from the same shop that's doing the frame around $150 to sand and clear coat the CF hood. Is that a good price? They said they've never redone one before. Either just installed them or painted to match car. Good deal, or should I get more prices?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-19-2007, 10:33 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: CF Hood Clear coat
Sounds a bit high, you might want to get another quote to compare.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-19-2007, 02:43 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
$150 to sand AND clear the hood? If they pay for the clear, that's a damn good price. Exactly what kind of sanding are they gonna do, are they gonna sand past the original "clear" and re-apply a new coat or are they just gonna scuff and spray over top of the existing one? Either way that's a pretty good deal granted they pay for the clear, just the labor on that would be more than $150 at any reputable shop.
95 Talon TSI AWD
97 Eclipse GST
Old 09-19-2007, 02:48 PM
Holset powered 420a
My guess is they will just give the hood a good wet sand. It wont take that much clear to spray a few coats on it.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-19-2007, 02:53 PM
david-b's Avatar
Dave is THAT guy
Ya they said wet sand the entire hood down and apply the coat then. Will ask about it again later, IF they finish my car today.
75 Monte Carlo
Old 09-19-2007, 03:10 PM
What's wrong with your hood that you want it re-cleared?
95 Talon TSI AWD
97 Eclipse GST
Old 09-19-2007, 03:46 PM
david-b's Avatar
Dave is THAT guy
Got a used CF hood. The clear coat is coming off along the drivers side, like peeling off and it's a good amount.If the front end is being rebuilt, I want the hood looking good too.
75 Monte Carlo
Old 09-19-2007, 03:54 PM
Is it an actual clear coat or is it a clear gel coating used to set-up the CF? If it's actual clear coat you'll be able to save it, but sanding down that gel shit sometimes causes more problems than you fix, but it'd be hard to tell without seeing it in person.
95 Talon TSI AWD
97 Eclipse GST
Old 09-19-2007, 04:14 PM
david-b's Avatar
Dave is THAT guy
I can peel it right off. The actual clear 'plastic' or whatever is over the actual CF is still there. It's just the very very top thin piece. I'll try to get a good pic of it later.
75 Monte Carlo
Old 09-19-2007, 06:58 PM
Holset powered 420a
I didn't know the hood needed to be fixed first. I assumed it was in good shape and just needed more protection. That price might not be to bad.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-19-2007, 09:51 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Is it a VIS hood? Because all there hoods seem to have a problem with clear coat. Whenever I get one (not sure which brand) I'm gonna put like 5 coats of hardcore wax on it as soon as I put it on.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 09-19-2007, 10:01 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
It sounds like a good price to me...I'd pay it if I needed this done.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 09-19-2007, 10:07 PM
david-b's Avatar
Dave is THAT guy
I know they all come off. I'm going to bring it in to the same shop that did the front and see what they say again. Actually bring the hood in and have them check it out.
75 Monte Carlo
Old 09-19-2007, 10:10 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Its not the epoxy resin that holds the CF together is it?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-19-2007, 10:15 PM
That won't help anything. It'll just make the water run off of it like a cheetah.
That's what I was getting at.
Dave, if you can pull off "chunks", then it's probably not clearcoat, clearcoat is less than paper thin and doesn't really flake unless it's a REALLY REALLY shitty job.
95 Talon TSI AWD
97 Eclipse GST
