Go Back   Automotive Forums Car Chat > Plymouth > General Discussion
Old 09-19-2007, 10:14 AM
ezab42481 ezab42481 is offline
94 Duster Hesitates Occasionally
Once and a while while driving my Duster 2.5 automatic I will be giving it gas and it just seems to bog down. It stays running just seems to have no power. I checked the codes and all I pull is the O2 sensor. I doubt the O2 sensor is making it run this bad. Any suggestions of what else to check?
Old 09-19-2007, 11:49 AM
taillight taillight is offline
Re: 94 Duster Hesitates Occasionally
If you have 100,000 miles on the car it is time to change the O2 sensor anyway. Yes the O2 sensor will do that.
Old 09-19-2007, 06:46 PM
squeaky3 squeaky3 is offline
could that be the same reason i dont seem to have much power when i accel at any speed
it just seems like i dont accel very fast or nething, even when i have it floored it doesnt seem like it accels that fast
could it be that or could it be becuz of the 3spd auto trans in it??
Old 09-20-2007, 07:40 AM
squeaky3 pull your trouble codes and see what the computer does not like first.
Old 09-20-2007, 12:14 PM
ok i
autozone will read the codes wont they?
i dont have a reader that will read from a 94
i work for ford so i have access to a scan tool but they r for ford and the like
i did have the check engine light flash on once in the spring but it only happened once so i didnt really worry about it to much
thanks
Old 09-21-2007, 09:11 AM
On a 94 duster you can pull your own trouble codes. Trun the ignition switch to on 3 times and leave it on the last time. Count the flashes.
