91 sonoma spare tire cable.
hi everyone,
on my 91 sonoma, the end of the spare tire cable underneath broke off.. is there a fix or do i have to try and find a whole spare tire cable unit? thx.
Re: 91 sonoma spare tire cable.
I went to GM Parts Direct Web site: http://www.gmpartsdirect.com/catalog/frameset.cfm and looked up the lift assembly in the alternate catalog and found it was about $12 + shipping. If you are bound and determined to fix the one you have take it to the hardware store and ask them for the cable repair stuff, I can't for the life of me remember what you call it but there is a piece you put over the cable and crimp in a vice. The counter guy at the hardware store will know what you need but take the lift assembly because you need to get the correct size. Good luck, Sparky |
I think sparky is talking about copper or aluminum sleeves for aircraft cable. Technically they should be swaged with a proper tool to ensure a proper crimping. You might also use a saddle clamp or crosby fist grip if you're concerned about getting a secure crimp.
My entire winch was seized so I cut the whole assembly out and bolted a piece of 1/2" threaded rod to the winch mount. You can then cut the nylon piece out of the original tire retainer and slip that over the threaded rod. Finish off with a wingnut and you've got yourself a new spare tire carrier.
'01 Chevy Blazer ZR2 4x4 VIN=W '80 Yamaha XJ650 Maxim '08 Jeep Patriot 2.4L |
