Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 09-18-2007, 09:56 PM
bdorris927 bdorris927 is offline
Banned
idle
on an 02 ls what are is the idel speed. when started goes to 1500rpm then down to about 700-850 nothing lower
Old 09-18-2007, 10:22 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: idle
That sounds pretty normal. You might get a more accurate response if you mention if you have the V6 or V8, but both should idle around the same engine speed, and what you describe sounds reasonable.
Is there a specific reason you ask?
-Rod
Old 09-19-2007, 08:34 AM
Banned
Re: idle
its a v8, it just seemed odd to idle that high
Old 04-30-2008, 11:09 PM
lumberjak1984 lumberjak1984 is offline
Re: idle
rite...i posted the same thing on page 1 of the forums. i was told either the egr valve or the iac valve. im checking my car tom.
Old 05-02-2008, 01:10 PM
gcwimmer gcwimmer is offline
Re: idle
My 2004 V8, depending on ambivalent temp, from cold starts at 1,500 to 1,700 rpms for 10 to 15 sec. then comes down to 800 rpms. It has done this from day one.
