Old 09-18-2007, 09:34 PM
JeenyusVR4 JeenyusVR4 is offline
Drive Train Problem!!!! NEED HELP
OK so i am driving my car around (i have a 92 vr4) and i noticed that the car would shift fine throughout all the gears all the way to redline, but when i got on it in any gear it would make a sound like the clutch was slipping. It felt like somehthing wasnt grabbing right. Si i had a couple people look at it and i came to the conclusion that it was my clutch cuz it was still the original clutch so i replaced it with a spec stage 2+ and lightened fly wheel. When i got my car back i broke it in for about 1000 miles and when i started to get on it, the same sound and feel would happen. It only happens when i really get on it, and does it it every gear as well. What could be the problem?? Could it be my transfer case or rear LSD? I really need to get this problem fixed. Thanks
Old 09-19-2007, 11:41 PM
2old 2old is offline
Re: Drive Train Problem!!!! NEED HELP
Ugh... I went through the same thing but I never figured it out... But as far as I could figure out:
It could be master/slave
It could be a bad rubber hose
It could be an out-of-spec flywheel
It could be air in the clutch line
So in the order of cheapest to most expensive:
bleed the clutch line again
change the hose leaving to the slave cylinder
Change the slave/master cylinder
Change the flywheel back to a OEM one.
If none of that works... Well I think someone here changed out the hard line for the clutch and it "appeared" to work...
Old 09-20-2007, 11:36 AM
ok thanks alot ill try those and see what happens
Old 09-20-2007, 11:44 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
A sound like the clutch is slipping? Could you describe that sound?
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 09-20-2007, 09:02 PM
ok the sound is kinda like a popping sound and it sometimes sounds like it backfired out the exhaust. I talked to one of my instructers at school (UTI) and they said the check the fuel consumption and things dealing with the fuel control. I guesse you could say that i feels like the car is bogging out.
Old 09-20-2007, 09:27 PM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
well if its bogging have u tryed to regap ur plugs? ik i turned my boost up and it would be fine untill i got on it hard that it would start to kinda stutter and bog but i regaped my plugs and problem solved, as far as the clutch im not sure.
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 09-20-2007, 09:48 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Clutches don't make sounds unless something is really physically broken on it. Sounds like you need to change your plugs.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 09-21-2007, 01:15 AM
ok sounds good i will definately try that if i just buy new plugs what should i gap them too. should i just gap them a little smaller than the regular spec. cuz i did do the free boost mod to my car recently so that sounds like that could very likely be the problem. thanks for the advice.
Old 09-21-2007, 01:21 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
I will hook you up with some NGK Vpower plugs (my personal favorit) and gap then for you if you want.. like 2.25 a plug no tax.. + shipping
Jason
Old 09-21-2007, 01:42 AM
thanks for the offer man but i have a gaper could you just tell me what gap size you would do that would be awesome also should i change the wires as well the wires i have are fairly new but to get rid of this prblem i will do anything
Old 09-21-2007, 01:44 AM
actually now that i think about it will it be cheaper if you do it for me? where do you live?
Old 09-21-2007, 09:14 AM
jason_bet's Avatar
utah.. but i am shipping from a bussiniess.. so shipping is a little cheeper.. Whats your zip code I will get you a quote.. also do you have a brand of wires you want prices on? or do you want factory?
Old 09-21-2007, 01:10 PM
my zip code is 60565 and i dont really care what type of wires i guesse prices on NGK wires and the factory.
Old 09-21-2007, 01:31 PM
jason_bet's Avatar
depending of production date (I can tell from your vin) Its 65-70 for factory plug wires NGK Wires are expencive.. like 110.. I can get you MSD wires (my favorit wires) for the same price (110) you also have a PM from me
Jason
