Old 09-18-2007, 08:11 PM
ColoradoSilverado ColoradoSilverado is offline
Eliminating Catalytic Converters
Is it possible to eliminate my Converters and just replace them with straight pieces of pipe ? Yes, I know it's illegal but my county doesn't require emission testing.
Bert
Old 09-19-2007, 07:10 AM
knogoodidleft knogoodidleft is offline
Re: Eliminating Catalytic Converters
anything is possible, what year/model, im pretty sure there welded on so you will have to cut them off. If your trying to reduce backpressure and still got the stock manifolds on I would advise you to replace them with some long tube headers.
Old 09-19-2007, 09:24 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
If 1980 or newer any car that is operated on a federal highway is required to have a cat.
Removing the cat can cause engine running problems.
MT
Old 09-19-2007, 09:49 AM
silverado122775's Avatar
silverado122775 silverado122775 is offline
The newer cars with Comps use the readings from the o2 sensors before and after the cat. you will run into issues
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 09-19-2007, 10:31 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Bert
MT is correct, while your county may not require emission testing, Federal law prohibits the removal of a catalytic converter, even by yourself. And last time I knew Federal law supersedes all local and state laws. I looked online for the text of the law,( it was the Clean Air Act of 1990) and came across this:http://autoparts.lifetips.com/cat/61...sions-control/
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 09-19-2007, 06:28 PM
vortecman's Avatar
vortecman vortecman is offline
have any of yall ever been to a tractor pull? to see all the smoke these trucks and tractors are putting up into the air is amazing! how come THAT is legal, but my truck would pollute too much without those cats?
Old 09-19-2007, 07:02 PM
First of all Diesel burn cleaner than Gas.
Second, if everybody took there cat off, then THAT would cause a problem. Society is trying to clean the air, not make it worse
Old 09-19-2007, 07:32 PM
The only reason I want to take them off is because they rattle like a yar of coins everytime I accelerate. New ones are expensive except the universal ones from Autozone that go for $59 a piece. Anyone ever used these ?
It's a 2000, 5.3
Bert
Old 09-19-2007, 10:44 PM
Those should be fine.. you may only need to replace one of them. I highly doubt both cats are bad.
Old 09-20-2007, 08:01 AM
No, it's both of them that rattle.
Bert
Old 09-20-2007, 09:15 AM
MT-2500's Avatar
AF - Advisor
Bert
Cats are covered under the 8 year 80k emissions warranty and Calf may be more.
Also some are covered under a recalls.
If both are bad you may have a bad batch.
Call the 800 customer service no in your owners manual.
Good Luck
MT
MT
Old 09-20-2007, 09:26 AM
MT-2500's Avatar
AF - Advisor
Here is a couple more links to the epa 1990 clean air stuff.
MT
http://www.epa.gov/air/caa/title2.html#iia
http://www.epa.gov/air/caa/caa203.txt
http://www.epa.gov/air/caa/caa205.txt
MT
Old 09-20-2007, 09:57 AM
Evansamms Evansamms is offline
I've got almost an identical truck (2000 5.3, 4x4, longbox, ext cab, (not Z71 though)), my right cat started poppin a code about 1000kms after the replacement limit. I picked up two magnaflow s/steel ones of ebay for 140 delivered. of course i had to take the y-pipe out, and weld them in .. ..but it wasnt that bad. Cheapest i could find cats here (halifax, nova scotia), was 140 each for "whitebox specials". Figured i was better off with the magnaflows.
Evan
Old 09-20-2007, 10:14 PM
vortecman's Avatar
even highflow cats will make your second o2 sensors send errors, won't they?
Old 09-20-2007, 10:21 PM
dirtdriver11 dirtdriver11 is offline
i was getting the po430 code also, i gutted both cats out and still have the problem. both o2 sensors are new on bank 2
