Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 09-18-2007, 06:22 PM
impalalover impalalover is offline
rear creak and squeak
I have an 05 impala,pretty sure the rear strut mounts are fine as they are not thumping like the other impalas i have has,the struts themselves are also good,when i pull in my driveway over the concrete curb there is a squeek in the rear like something is dry,othere times are over the speed bumps,or certain bumps in the rd,it is not inside the car it is underneath in the rear as i rolled the car back and forth going into my driveway and can here it underneath the car,after numouris attempts to find this creaking i cannot fint ,i took all the rotors and pads off,not the breaks,while under the car in the rear i bounced the car up and down and it will not squeak at all or from side to side,only here it when driving in and out off the driveway or going over speed bumps,can anyone tell me what the hell else this counld be and how to try to pinpoint the noise,also i lubricated the top of the strut mounts in the trunk of the car still creaking
Old 09-18-2007, 07:14 PM
Re: rear creak and squeak
someone mention that it might be the rear sway bar bushings,what do i do to lubricate those,take them off or go around what i can get at with some wd40 spray,anyone have any suggestions
Old 09-20-2007, 03:32 PM
not the rear sway bar bushing,took off the sway bar greased up the six of them,squeak still there,anyone out there have this problem and had it fixed,if so what was causein the car to creak going over curbes and speed bumps,thanks,anyone know
Old 09-22-2007, 07:26 PM
sprayed 2 big cans of wd40 under neath the hole under carriage of the rear of my impala,everthing from every bushing and moving and non moving parts,including lifting up the dust covers on the rear struts sprayed everthing mounts struts and mounts even the top of the rear mounts in the trucnk,still have that annoying creak in the rear,change rotors and pads,check all bolts,lube the sway ar mounts even took them off,while pulling into my driveway with my head hanging out under the car while i am reversing and going forward over the concrete hump in my driveway i can still here the crunch and creak under the rear of the car and over speed bumps,starting to piss me off now,anyone know what else to check,though i had everythimg covered
Old 09-23-2007, 07:45 AM
57chevyragtop 57chevyragtop is offline
Send a message via MSN to 57chevyragtop
Perhaps it is not in the suspension but caused by body flex. might try grabbing your muffler and give it a shake rubber mounts could be cause, parking brake cable, check attach points of flexible brake hose, fuel lines. I've read here in posts about noise searches some use mic's taped to trouble spot area to listen through amplified device or recorder. Isolating annoying sqeaks and rattles is frustrating.
Old 09-23-2007, 08:19 AM
thanks for the reply,i also did check all those things too,can't see to find the noise,when i grabbed the exhoust it was quiet,checked the brake lines also,will check again though to be sure
Old 09-23-2007, 10:33 AM
It is possible I guess for one of the struts to be cause with out being "bad" so to speak....worth a change out? Not really for a noisy op...I would even check spare tire bolt down, trunk gasket. Could always strap a neighbor kid under there....
Old 09-23-2007, 11:23 AM
ya i tightened down the jack and what are u taking about trunk gasket
Old 09-23-2007, 12:21 PM
checked her again lyning under the car bounceing her up and down till she alsmost bounced off the ground and from side to side,not a sound only the gas from the rear struts,don't creak and squeak till i drive over certain bumps,coming in the driveway or slow down bump stops in the rd,i don't know where else to look
Old 09-23-2007, 03:33 PM
i lubed all the exhaust rubber mounts,2 rears,one down under the rear pass side door and the 2 round gasts in front of the converter,as i removed the 2 donut stle rubber mounts i could here a real good squeek as i moved the whole exhaust back and forth,i pinpointed the noise up front for the squeeking to be where the exhauted bolts to the back of the engine,used half a can of lube on it from underneath the car and from the top,there is no squeek there now ,have not tried the car yet to see if it fixed the creaking or not,is it possible that where the front flange on the exhaust where it bolts to the front of the engine carrying the sound of this creaking from the front of the exhoust to the rear
Old 09-23-2007, 07:29 PM
i give up,can't find out the problem
Old 10-20-2007, 05:46 AM
i found out that after all the foolin around o find that rear creak thats in my car was the rubbers that go over the rear coil springs in the rear,upon changing my rear rotors and pads yesterday i noticed that when the car is lifted up the rubbers that meet together on the bottom 2 coils there are little dowels that rubbed through the last coil spring from the one on top of it down into the metal,put a pile of grease where the dowels meet the rubber where the spring rests on when the 2 come together when shes on the ground and the squeak is gone
