Old 09-18-2007, 05:42 PM
maryinaz maryinaz is offline
89 wagoneer limited problems
i had a question about some new problems with my 89 wagoneer that came out of the blue today ... everything was going fine earlier, when i went to leave a while ago, my turn signals, radio, and air conditioner were not working ... maybe a blown fuse? ... my haynes book i have shows no fuse panel diagram and i have no idea what to look for ... if anyone has any ideas it would be appreciated, thanks in advance
~Mary~
Old 09-22-2007, 05:52 AM
Stick89's Avatar
Stick89 Stick89 is offline
Send a message via Yahoo to Stick89
Re: 89 wagoneer limited problems
Yeah.....start with the fuses...
WOULDN'T IT BE NICE..IF WHEN WE SCREWED UP..TO JUST HIT..CLT...ALT..AND START ALL OVER AGAIN
Old 09-22-2007, 12:33 PM
citizen@large's Avatar
citizen@large citizen@large is offline
Any feedback on what happened here? Was it a fuse or what?!
Need any more help?
Old 09-25-2007, 07:35 PM
MasterMouse MasterMouse is offline
Ok here's the deal. I had the same problem with a 89 Jeep Cherokee.I checked all fuses even done a wire test tracing each wire down. Come to find out the problem was simple...Look under your dash right at the base of the steering colum right on top of it there should be 2 set's of wire's plugged in to a junction box . One set with a blue hook up and a set with a black hookup. Un plug them and inspect the wiring. Mine had one wire that had burned into.I replaced the end of the wire...and hay i had all my stuff back I think they call that a Ignition Switch wiring relay. Not really shur but Hay i hope this help you and get's you on your way .Good Luck .....
]v[aster]v[ouse .
Old 09-26-2007, 06:04 AM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
That's not an ignition switch wiring relay that is the ignition switch itself.
