| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Car dies after getting on it???
Ok everyone I have a 97 GST and I have been having a problem with it stalling after I give it almost full throttle? Sometimes i let off and it will almost die but will jump back up to normal rpms and sometimes it will die after i let off. any ideas? Other than that it runs fine. No CELs.
Re: Car dies after getting on it???
It looks like your venting your bov in the pic from your sig. That could be your problem.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Hey man, good to see ya again. Boost leaks? Its not making any extra engine noise i.e. ticking is it?
Yeah I am venting, but I don't think there is a way to recirc the Apexi dual chamber BOV is there? The only ticking i hear is lifter tick and thats only when I first start it up or its almost time for an oil change for the most part.
Hey thor! i haven't been around hear as much lately because I am so busy lol you know how it is. I'm actually thinking about selling the ol' DSM but I can't with it doing this..... I want a truck REALLY bad and i need something a little more reliable and newer. I hate to get rid of her but life goes on i suppose. |
Im going to say its your bov not recirculating. You run so rich when you let off the throttle that it bogs the car down. See if you can somehow recirculate that one to see if it helps, or put another one on it if you have one.
I don't have another one. Does anyone know how to recirculate this BOV?
I also kinda have the BOV rigged on there because I can't find a flange for the apexi BOV that fits a greddy flange! so it may be leaking. It seems like i have looked EVERYWHERE!
Sounds like you are down the creek with no paddle my friend.
there has to be SOME way of recirculating it. I dont see why they would make a $2-300 BOV that you CAN'T recirculate! Anyone??
Cut some hose and use some duct tape I guess.
Im surprised you have no CEL's. When I vented mine to atmosphere, I got about 3 codes. It would run fine until I came to a stop, or pushed the clutch in, then it would try to cut off on me. Thats a strange looking BOV, I'm not sure how you would go about recirculating it. Unless you can buy a recirculation kit, like you can on the HKS BOV's. What kind of BOV flange is that on your UICP?
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can 94 Talon 1.8L-SOLD 02 Civic EX- Daily driver (staying stock) |
the UICP has a Greddy flange. will the 1g BOV fit on that flange?
This is actually the one I have: http://www.turborx7.com/images/Technical/apexibov.jpg |
I had the same problem on my GS-T. Under heavy boost or when I would stomp it, sometimes the car would die. (I also did not pull any CELS)
I had the same BOV as you. I swapped it out to a Greddy RS with Greddy UICP, and no change. I am willing to bet it is NOT your BOV. Just because he doesn't have it recirculating doesn't mean it magically is the cause to all his problems. Does having a vented blow off valve cause problems? Sometimes, but I doubt that is what this is. As to what is causing it? Don't know, I never figured it out on mine.
1991 GSX 2.3 Stroker |
I forgot to say that it doesn't die if it is in gear when I let off the gas its just if I put it in neutral or push in the clutch after giving it a decent ammount of gas (not WOT).
