Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-18-2007, 03:19 PM
jclamphear jclamphear is offline
Question Engine stalls when clutch is engaged
I have searched through the forums and think I have found some answers, but not completely so I am going to ask the group. My son has a 97 Eclipse, 2.0L w/ a new Turbo / cold air kit / blowoff w/ manual transmission.
The car is hard to start and I find it stumbles bad when the clutch is engaged (need to have the clutch in to start!). Once it starts, I immediately let off the clutch and it idles fine and engine runs smooth. As soon as the clutch is engaged, it will die. If I keep the rpms up, I can engage the clutch and get going while it is stumbling and then the engine seems to run fine, as long as I do not let up off the accelerator when the clutch is engaged.
The check engine light is on and I have not had the codes read. My son said he believes it needs an O2 Sensor.
My question is, what other things would make the engine stumble and stall when the clutch is engaged?
Can anyone provide me some insight or point me to a post that may address this problem? Thank you in advance.
Old 09-18-2007, 03:25 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Engine stalls when clutch is engaged
I would suggest getting those codes read, and doing some maintanence on the car. Plugs, wires, fuel filter, maybe even run sea foam through the motor. Its probable just a sensor that needs to be replaced.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-18-2007, 04:24 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Yep, pull codes first and fix that. If the problem persists then give 'er another go.
As for having the clutch in to start, that is from the factory on these cars. If you want to be able to start it without the clutch pedal depressed, its as simple as disconnecting the clutch sensor up by the pivot point on the pedal itself.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-18-2007, 10:59 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Yes like Thor said there is a little plug at the very top of the clutch pedal that you can just disconnect and it will not require the car to have the clutch engauged while you are trying to start it.
As far as the car stalling when the clutch is pushed in. I had the same problem when my motor was what we call crankwalking, another term would be thrust bearing failure. You can do a search on it but pretty much what could be happening is that when you push the clutch in it is putting enough pressure on the crank to push it up against either the crank girdle or wall of the block to wear it is slowing the crank down enough to kill it. A good way to check if the car is crankwalking would be to jack the car up and get underneath with a crowbar. Pry the harmonic balancer towards the block and have someone in the car push the clutch in and see if it is moving back and forth.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 09-18-2007, 11:03 PM
Holset powered 420a
Now dont go putting crankwalk into his head.
I believe he means releasing the clutch when he said engaging. So that shouldn't have anything to do with crankwalk.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-18-2007, 11:08 PM
Thor06's Avatar
Jizzed In My Pants
Its a possiblility though. Does the clutch pedal fall to the floor when making left hand turns?
