Old 11-24-2002, 05:31 PM
danduke1 danduke1 is offline
Unhappy my brakelights just stopped working
i have a 94 bmw 318is and all of the sudden all of the brake lights stopped working. all of the other lights still work. i checked all the bulbs and the fuse and all are good. could anyone help me
Old 11-25-2002, 01:59 PM
ales's Avatar
ales ales is offline
Forza Schumacher
It's either a broken switch (sorry, I don't know where it is on your car) or the wire (probably still around the switch area) that is not conducting electricity. If all 3 of the lights stopped working at once, I find these two the most likely suspects. I'd locate a switch and run a wire from it to some bulb (control lamp) that you are certain is working. Push the pedal. If the bulb ligts up, the problem is with the wire(s) going from the switch to the lights. If the bulb doesn't light up, I'd try connecting the wire to the other end (electrically speaking) of the switch and see what happens. If it lights up then, it's the switch, if it doesn't - the current is lost on the way to the switch. Good luck.
automatic door just stopped working--why?? primarycolorinc Odyssey 8 11-20-2014 12:41 PM
A/C just stopped working and light blinks... JimB442 Intrigue 3 11-08-2005 07:49 PM
My wipers just stopped working.....PLEASE HELP!!! officer629 Probe 0 09-10-2004 08:32 PM
Cruise control just stopped working DigMe Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 06-08-2004 09:17 AM
