Old 09-18-2007, 01:43 PM
duke_winchester duke_winchester is offline
turn signal problem
have been having a/c problems, but I added refrigereant/sealant today and so far so good. However, today, my right turn signal went wack. When I turn it on, the indicator on the dash flashes and clicks at a very fast (abnormal) rate, and the right front turn light flashes just as quickly, but the rear right light does NOT flash. Could this be as simple as a bulb? I checked the bulbs in the rear right housing and all filaments seems good.
Thanks
Old 09-18-2007, 02:40 PM
buckeye1872 buckeye1872 is offline
Re: turn signal problem
more then likely just bad bulb in front.
Old 09-18-2007, 02:55 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
yes, it's a bulb. The GM electronic flasher units will flash rapidly to indicate a burnt out bulb. The old thermal flashers wouldn't flash at all when a bulb burnt out.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
