Old 11-24-2002, 04:45 PM
glassman glassman is offline
Question Brake job on a 97 Hyundai Accent
Help, I am trying to do a front brake job on my 97 Hyundai Accent. I have done brake on other cars over the years. I cannot get the rotor off. What am I doing wrong? This is usually a pretty easy job.
Old 11-24-2002, 07:51 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Are there two phillips screws next to the studs? If so, undo them. Then there should be two holes for a bolt to be threaded into, next to the studs as well, right? Use a long bolt, and thread it into the holes.
Old 11-24-2002, 10:28 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
I'm assuming that you have the caliper out of the way, etc?
I don't know anything specific about the design of the hyundai brake rotors. Based on previous experience with tough-to-remove rotors on other vehicles, I have the following to add to what was said above:
If you absolutely can't get the screws out (stripped the slots, etc), drill them until you take the tapered heads off (but only go as deep as you have to). Then whack the rotor with a mallet until it vibrates loose. Grip the remaining portions of the screws with vise grips, and twist them out. Replace them with new ones when you put the new rotors on (that's why you're taking them off, right?), but dab some disc brake grease on the new screws before you put them in, and don't torque them very tight at all. Those screws are only there to keep the rotors in place until you get the tires on (they're not all that important).
If you're in the unfortunate situation of having rotors that are mounted from behind the hub assy (as in the honda accord), then the above doesn't really apply.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 11-25-2002, 09:10 AM
Will the long bolt trick work with the rotor being behind the hub?
02 Blazer DIY Brake Job Advice Brndo Blazer 6 03-13-2011 09:35 AM
Hyundai Accent Exteriors nihariak Accent | Verna 0 10-20-2010 12:33 PM
Front Brake Job - Replace Rotors? buickultra2000 Park Avenue 3 02-09-2010 07:11 PM
