Old 09-18-2007, 06:03 AM
cfcrules's Avatar
cfcrules cfcrules is offline
Airbrush Valve Problems
I have a badger 200 bottom feed airbrush, and the air no longer goes through the valve assembly, I was wondering if anyone knew what the problem was and if there is anything that I can do?
Thanks
Old 09-18-2007, 06:27 AM
klutz_100's Avatar
Re: Airbrush Valve Problems
something somewhere is probably clogged with dried paint?
have you stripped it down and cleaned it out thoroughly? Or maybe the trigger valve is jammed?
Are you getting no air at all or just a weak stream?
Old 09-18-2007, 07:26 AM
sjelic's Avatar
sjelic sjelic is offline
This is probably the problem, remove trigger valve from AB and put it on hose (just valve), turn on compressor and push valve pin, if there is no air that is your problem, you probably washed it in some hot thiner and rubber seal stuck. You will have hard time to unstuck that, leave it in alcohol for a while, maybe it will work.
Sasa Jelic
SCALEMAKERS
Old 09-18-2007, 07:35 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
That's my guess also. I made that mistake myself once. After I was convinced I'd well and truely ruined it, I did manage to free the valve and it's worked OK since. But don't soak airbrushes in thinner.
Realisticly the worst case scenerio is that you'll have to disassemble the trigger valve and replace the sticky component. The replacement part shouldn't be hard to come by.
PHOTOBUCKET SUCKS
Old 09-18-2007, 05:09 PM
cfcrules's Avatar
Hi, thanks for the help, the rubber had expanded and i had to use pliers to get in there, and then soaked in warm water, the airbrush now works fine. Cheers
Chris
