Old 09-17-2007, 07:19 PM
96_blazer_5spd 96_blazer_5spd is offline
Question 1999 w/4 button 4x4, doesnt work
ok so i have a 99 that i have replaced the encoder motor on, and the dash switch and still nothin happening to engage 4x4, fuses are good, power running to switch, the back illumination lights are on but it only has gear selection lights sporadically and then only 4wd auto. any ideas?
Old 09-20-2007, 06:20 AM
travis00 travis00 is offline
Re: 1999 w/4 button 4x4, doesnt work
Its 1 of 4 problems
1 encoder
2 switch
3 tccm
4 wiring
You already changed out 1&2. The tccm (transfer case control module) is behind the pass. side kick panel.Do u ever hear any relays clicking from the tccm? Also check the connector going to the tccm. I've heard of wires pulling out of the connector.
Is the service 4x4 light on?
I'm having problems with my 99 as well. Sometimes i get no lights on the switch sometimes I get all the lights. I was told you can ground pin 13 of the OBD2 connector and get a code, but there is no pin 13 on my connector.
Took mine to autozone to read codes and service 4x4 and ABS codes cann't be read with a hand held scanner. Has to go to dealer to read codes.
Let me know what you find
T
Old 09-20-2007, 07:55 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
You need to get it on a good transfer case/transmission /engine capable scanner to get to the problem.
Usually there is some test in the scanner and codes to point you in the right direction.
If you can get codes post back code no.
MT
MT
Old 09-20-2007, 09:45 AM
laxman21's Avatar
laxman21 laxman21 is offline
Have you checked the vacuum valve/switch on the fire wall?
It's right in the middle above the distributor.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 10-02-2007, 07:13 PM
sorry for the late replies, i havent been able to get it on a scanner yet, and travis if you have switch with the 4wd auto button, it is a 236 transfer case and can only be read with a scanner, the 233 can be grounded for the codes
