Old 09-17-2007, 06:58 PM
automan25 automan25 is offline
transmission pan gasket
I plan on removing the transmission pan to change the fluid out. Do I need to get a new gasket for this. If so, do I also need to use RTV sealant?
thanks,
-Jeff
Automan25
1999 Intrigue GL
3.8 litre engine
Old 09-17-2007, 07:46 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: transmission pan gasket
You should be able to re-use the gasket, they are designed to be re-used and will work fine unless somehow damaged.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 09-19-2007, 06:28 PM
panzer dragoon panzer dragoon is offline
the gasket is a plastic/rubber compound. 7-8ft lbs of torque max or else you will smash the gasket. Finger tight all the bolts first evenly.
