2003 Accord..ABS "wheel" for sensor
Hello , I have a 2003 accord (2 door EX) . I am trying to locate the "sprocket" for the ABS sensor for the front . I can't see any "teeth" . I did see some semblance of teeth in a rubber o-ring inside the hub . When I installed the new ABS sensor it was at an angle and I think it tore the rubber "wheel" for the sensor to pieces .
Thanks ,, Shannon |
Re: 2003 Accord..ABS "wheel" for sensor
As far as I know the sensor ring is part of the hub and has to be replaced as a unit.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
Thanks Jeff . Typically the teeth are metal and very visible but I can't see them on this unit . I will have to remove the hub and look closer . Removing the hub is another question I posted and someone has answered already . I may try this weekend.
Thanks again for your help, Shannon |
