Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-17-2007, 04:11 PM
mendenken mendenken is offline
Check engine light on with P0171
Hi All,
I have camry LE 1999 model(4 cylinder). I have the check engine light on for last few months. I ignored it as there is no problem in use. I have the inspection due by the end of september. I read somewhere that the P0171(System is too lean on bank1) is due to the dirty maf(mass airflow sensor). How can I clean it, is it safe to clean my own.
I heard that is very expensive piece.
Also, I haven't done any filters changed for last 90 thousand miles. Would that be a cause of the "light on"
Any input is appreciated.
Thanks
Old 09-20-2007, 12:14 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Check engine light on with P0171
This won't be identicle to your car but, should give you the general idea: http://www.lexusownersclub.co.uk/kno...v2&id=152&c=11
A little more info: http://www.obd-codes.com/trouble_cod...gen-sensor.php
Download your factory maintenance manual from the Factory Service Manuals thread at the top of the forum. The FAQs thread should also have more info.
MAF sensor should cost $150-$200 for your car. May be cheaper on the net. Maybe Ebay.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 09-20-2007, 08:33 PM
2000izusu 2000izusu is offline
keep in mind po171 is one of the hardest codes to diagnose for the do it your selfer. could be a vaccuum leak, fuel system problem, maf mentioned above etc... becareful with diagnosis.
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Old 09-20-2007, 11:43 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
http://www.automotiveforums.com/vbul...d.php?t=732698
Different engine, same problem to solve
MAF meter resistance and long-term vs short-term fuel trim will determine whether it is the MAF meter or not. Resistance will diagnose ECT sensor.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 11-24-2011, 05:25 AM
artbuc artbuc is offline
Brian, how will the fuel trim confirm a bad MAF? What will the short term and long term fuel trim be if it is a bad MAF? Thanks.
Old 11-26-2011, 01:23 PM
Brian R.'s Avatar
Resident Chemist
In the freeze frame output, the total of LT and ST fuel trim should be less than 35%. My total in the cited example was 41.3%.
If the fuel trim total is greater than 35%, and the MAF resistance is marginal, then the freeze frame values confirm the MAF meter is probably the problem. This is not a sure thing. There are many possible causes for this code.
Old 11-26-2011, 05:29 PM
Thanks Brian. Why does your scanner show ST and LT fuel trims for Bank 3 at 100.6%? What is Bank 3?
Old 11-26-2011, 11:25 PM
Brian R.'s Avatar
Resident Chemist
I don't know, but I would guess it is an unused channel. The values are meaningless. Maybe it is used when there is a bank 2 sensors 1 and 2 A/F Ratio - HO2 sensors (dual exhausts).
