Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 09-17-2007, 11:20 AM
procrstinator procrstinator is offline
wont start
2000 elantra cranks but wont start,,driveing to work and it just shut down with no warning .there was no check engine light no codes with the obd 2 code reader .. the fuel is there ...help
Old 09-17-2007, 11:44 AM
Jalmir's Avatar
Jalmir Jalmir is offline
Re: wont start
you say you have fuel, you checked and your fuel line is pressurized? (you should have aroud 30-35 psi)
you have sparks?
what you can check is the crankshaft sensor, the MAF, the coil pack, the fuel pump and the ECU.
Old 09-17-2007, 12:57 PM
Re: wont start
correct me if im wrong but shouldnt those error codes have shown up on the obd2 reader..???? im going to start with the crankshaft position sensor . thanks
Old 09-18-2007, 03:45 PM
peachferrari peachferrari is offline
Re: wont start
Most check engine codes are for exhaust/emissions related items. You probably won't get a code if it's just something electrical.
2005 Tiburon SE 2.7L V6 6sp manual
2008 Santa Fe Limited AWD, 3rd row, Nav
Old 09-18-2007, 05:05 PM
Jalmir's Avatar
Re: wont start
yeah there will be a code for those sensors (MAF, cranshaft and coil), even a code if the ECU is busted (I remember seeing it in a code list). But there will be no codes if the sensor dies and the car won't start again (my crankshaft sensor died, engine stalled and I never got any codes, the car wouldn't run at all so it never registered in the ECU).
