Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 09-17-2007, 10:57 AM
jdclassen jdclassen is offline
O2 Sensors
I have been having problems with a rough Idle when the engine is first started. Always maintained engine with oil and clean filter(K&N) new plugs installed 6-months ago. I am thinking that maybe the computer is not mixing fuel and air properly, so the O2 sensors need to be replaced.
Does anyone have another Idea of what It could be, and how to diagnose the issue? and Should I do the O2 sensors myself? I understand there are 4 sensors 2 on top and 2 on bottom, could one go wrong and not the others causing this issue?
Thanks,
Jeff
Old 09-17-2007, 01:40 PM
reekor reekor is offline
Re: O2 Sensors
Jeff, Here's my two cents on the issue. Before replacing the O2 sensors, I would clean the MAF sensor, because more then likely your oil filled K&N filter gummed it up.
Thanks,
Jeff
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 09-18-2007, 08:32 AM
Stale Trooper's Avatar
Stale Trooper Stale Trooper is offline
Re: O2 Sensors
If your O2 sensor(s) are bad, you should be receiving a "Check Engine" light. Cleaning the MAF is a lot cheaper than an O2 sensor, easier also. Good Luck!
Stale Trooper
'05 CVPI
(My '99 got wiped out with 238,513 miles on the clock, stupid woman driver)
It's White, with a black grille, a spotlight, and the butt is black. Need a picture? Thought not
