Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 09-17-2007, 09:11 AM
StellarSupra270 StellarSupra270 is offline
Smoke...
So I'm driving and I stop at a stop sign and POOF a bunch of smoke comes pouring out of my vent from my hood. It smelled...hmmm, I don't even know. Not sweet really, but Yuck. Anyway, so I found a bit of corrosion from my radiator hose, so I changed the hose clamps and the hose. I cleaned off my engine, since I did notice a bit of oil by the seals. Well, even after those changes, my car is still smoking. It happens only every so often. The smoke isn't black/blue, it's definitly white. /sigh Help.
*~Michelle~*
~~2004 Dodge SRT4~~
K&N Typhoon Intake, GReddy TypeS bov, Exhaust Depot hard pipes......
Old 09-17-2007, 04:28 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: Smoke...
Probably radiator related. Is your water temp gauge in the car working? Does it happen when it's hot out, when you run your AC, when you are idleing for a while, or just out of nowhere. I would say get your thermostat changed, make sure all of your water pump stuff works, and make sure your radiator is able to flow air through it and doesnt have debris covering it. Other than that not sure...although I really doubt it anything besides your cooling system.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
