Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-17-2007, 08:16 AM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
Question More Power
I'm trying to squeeze some more power out of my non-turbo car, i am looking to buy a gsx down the road as a full blown, re-done front to back project car, and i just want to do what i can to my RS to get as much power out of it as i can without having to rebuild my entire engine. I already have a full header to tip exhaust, CAI on the way, new plugs, wires, battery, and im looking to get a new bored TB before i get the intake so i can do that all at once. Besides that im really not sure what to do except the new UDP someone suggested. Anything else, im really not sure where to go... i know a clutch and flywheel will help out, but i dont want to do that quite yet, and i have heard most people say that when they upgrade those it makes shifting stiffer or just different in a bad way, so im trying not to do that for the time being untill i get it all figured out.
Anything else, thats not to major i can look into?
-I really dont want to get into nitrous with this car, and i have decided not to turbo it because i want to get a GSX down the road so i would want to save that money for then..... plus its always fun to have something like my RS which is a nice little semi-modded car to fuk around with.
Thanks
97' Eclipse RS 5 Speed 420A
Under The Hood:
Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires
Interior:
Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout
*GOAL* - Prove Him Wrong
Originally Posted by UnderEstimate Me
I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs.
Old 09-17-2007, 09:37 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: More Power
Thats pretty much all I would do. You can do some weight reduction, short shifter, and make sure all the maintenance is done.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-17-2007, 10:29 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: More Power
yea there isint a whole lot left you can do.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-17-2007, 02:18 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: More Power
Maybe a ported intake manifold? You could always do what David-B did and do a head build. If you need things to do with your RS, just look at David-B's car, he has done pretty much everything you can do to an NT RS/GS.
1991 GSX 2.3 Stroker
Old 09-17-2007, 03:55 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Lightbulb Re: More Power
Everything but a built block and nitrous. A ported manifold won't have any gains unless you get the head done. Ya, it opens up the runners a little and smoothes them out, but that won't do anything if the head itself isn't sucking extra air in at a high rate. It would basically be a waste of money done by itself. With a built head is it worth it? Don't have money to dyno before and after porting IM, so who knows.
Also, an OBX or Venon manifold replacement would also be a waste as those are completey smooth on the inside. On a N/T car, you need the roughness of the stocker IM to "shake up" the air a little.
Weight reduction would be a good thing to do. What's it, for like every 100lbs you drop off the car you gain 1/10th of a second or something? Something to think about it; is it worth it?
Something you may want to do, talking about maintanence is using engine cleaner next time you change your oil, F.I. cleaner in a couple tanks of gas with premium gas. Even pulling the injectors and cleaning them manully. Use some fluids/cleaners that are meant to clean the valves and working components of the engine. Just some stuff that will clean up the crap in the motor/gas/oil that may slow you down a little.
Don't do the clutch/flywheel until you actually have to drop your tranny. I needed a clutch, but waited until I blew up the tranny before I replaced it. Unfortunately, I then didn't have money at the time for a lightened flywheel, and had to get a stocker flywheel.
My suggestion honestly, since you plan on buying a GSX in a little bit, why not just keep the RS going and running strong, and save your money. Then you can get a GSX in good conidition and have money left over for upgrades/maintinence right away.
With that, I think I'm going to write an articlc about this all.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-17-2007, 08:21 PM
Re: More Power
Sounds good, thanks a lot!
Under The Hood:
Interior:
