Anti lock warning light
1994 TC, in the past 3 months, three times when the brakes were pressed they grab very abruptly, the anti lock light flashes three times, blinks three times and the light stays on. The light goes out when the car is turned off and doesn't come on unless this even occurs again.
Any thoughts? Thanks in advance |
Re: Anti lock warning light
Most of these ABS problems are traced back to wheel sensors or wiring to the wheel sensors. If your ABS light is on you'll have to have the stored fault codes pulled with an appropriate scanner, and take actions depending on that result.
This service manual is available on my web site, here a quote: «1994 Town Car/Crown Victoria/Grand Marquis Table of Contents» «Group 06: BRAKE SYSTEM» «Section 06-09: Brake System, Anti-Lock» «DESCRIPTION AND OPERATION» Brakes, Anti-Lock Anti-Lock Brake System (ABS) operates as follows:
-Steven 1996 Town Car, Cartier |
I had that problem - anti lock warning light on intermittantly. Ford charged $90 just to read the codes! They included that in the $240 to replace the module for the LF wheel -- wasn't that kind of them?
Stan'98 Lincoln Towncar - white 100k '08 Mercury Grand Marquis - maroon 30k '98 Dodge 3/4 ton, Cummins Diesel, 4 x 4, 4 door, extended cab, long bed. 140k |
Can the service codes for the ABS be pulled by jumping the computer plug and reading the flashes on the dash warning light like can be done for some of the service codes?
Thanks for the replys Haydad |
My understanding is that there is a different computer plug, for a different computer for the ABS. I could be all wet.
Is the ABS light different from the antilock light?
Are the wheel sensors items that can be replaced by a mechanically inclined guy or is this an item that should go into the shop? Thanks |
Did you get my 1993/1994 FSM from my website? It details the sensor replacement procedures. There's some talk, a TSB too, saying that many of these type of problems are a bad connection to one (or more) of the sensors. The recommendation is to unplug each sensor and clean the connectors, spray some stuff in there to further protect it, inspect the wire harness condition, and re-assemble. Since you don't know which one might be the problem, this can be tedious. The FSM (others may know this) tells the resistance values of the sensors for testing them. Also, the stationary sensor 'reads' a spinning ring gear, that air space between the two may be clogged with brake dust, you'll have to remove the wheels to clean that out. Here's some basic overview shots; more detail is available from that FSM:
