Old 09-16-2007, 08:47 PM
rloya99 rloya99 is offline
2002 accord
could someone tell me where i could find the obd conection on this honda looked everywhere and can't find it thanks
Old 09-17-2007, 07:40 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 2002 accord
1998–2002 Accord
If the malfunction indicator/Check Engine lamp remains lit or comes on while the engine is operating, the ECM has detected a malfunction and has stored a DTC in its memory.
To access the DTC memory using a scan tool, connect the Honda PGM Tester or an OBD II scan tool to the 16-pin DLC. The DLC is located under the drivers side of the instrument panel. Turn the ignition On and begin troubleshooting as indicated by the tester, following its prompts to diagnose the error. If unsure how to operate the scan tool or PGM tester, refer to the tool user’s manuals for specific operating instructions.
Data Link Connector (DLC) locations. 1998–2002 Accord
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 09-17-2007, 01:48 PM
Re: 2002 accord
thank u for the help
Old 09-17-2007, 01:50 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
Question Re: 2002 accord
make sure you check on the passenger side next to the center console i have seen some hondas have the obd 2 connector there too.. and some have a pop out cover you have to remove
