Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 09-16-2007, 07:54 PM
doctorheat doctorheat is offline
just got a 327
My girlfriends dad has a 327 in great shape. the catch is that it is a "Gold Edition" which has a 5-bolt main (so im told) and just wondering if a 350 tranny would hook up to it.
Ill be the first to admit i know jack bout chevy's, so im hoping someone here knows...
Old 09-17-2007, 07:41 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: just got a 327
Well, there is no such animal as a 5-bolt main anything. The 327 only was offered as a 4-bolt main in the Vettes, at least as far as I've seen. I've never heard of a Chevy gold edition 327, but there were some Chevrolets called gold edition.
The good news is that it will bolt up to a Turbo 350 transmission. The best thing for you to do would to decode the engine number and see what you have. There are many sites online, just do a search under "chevy engine codes" and you should be set.
The main engine ID number is located on the front of the engine block, just ahead of the passenger side cylinder head.
Bob
Old 09-17-2007, 12:37 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: just got a 327
Sure there is! Don't you remember those engines with the square pistons?
J/K
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-17-2007, 03:39 PM
Re: just got a 327
Alright, that sounds alot better (and cheaper) than what i was being told
Thanks
Old 09-18-2007, 08:13 PM
HENRYFORD's Avatar
HENRYFORD HENRYFORD is offline
Re: just got a 327
I have a 1979 trans am and it has a 1968 327 big journal that I just completley rebuilt everything is new it is bored .060 over with 1996 vortec heads shaved .030 high performce hei ignition and a performance and a brand new 750 dual line holley carb and the problem is it misses real bad and when you put in gear it dies and it has done flooded 4 sets of spark plugs.PLEASE any help would be more than greatly apprecated it's driveing me crazy!!!!!:]
Old 09-18-2007, 10:21 PM
silicon212's Avatar
Confoundingly Lucid
Re: just got a 327
Well, at least you had two long run-on sentences instead of one longer run-on sentence.
If you want to repost this using punctuation, I will read it and reply.
Old 09-19-2007, 06:12 AM
bobss396's Avatar
Re: just got a 327
With a name like "henry ford" your stovebolt is trying to send you a message, also it is not cool to hijack someone's post for your own needs.
Only knowing what is in front of me here, a 750 is probably a lot of carb for what you're doing. The first think I'd look at is the basic float level, get that right and see what happens.
Bob
Old 09-19-2007, 07:10 AM
HENRYFORD's Avatar
Re: just got a 327
Thanks I'll try that
Old 10-02-2007, 08:54 PM
Torch Torch is offline
Re: just got a 327
Doctorheat,
I used to have a 68 Impala that had the 327 engine, 1968 and 69 were the only two years that had the large journal version of crankshaft. As far as the five-bolt-main goes as someone already said there is no such thing.
The Chevy Small Block came in two bolt main and four bolt main, even if you look up the casting number (on back of engine behind the driver's side head) and it says four bolt main the only way to really know for sure is to drop the oil pan and look. There should be five caps holding the crank shaft on, they will either have two bolts or four.
Some people replaced the bolts with studs and nuts to hold them on, apparently they were supposed to be stronger than the bolts were, other people cut the caps flat and put a piece of steel across the cap to hold it down with. I have no idea if any of this actually kept the engine together.
There are numerous modifications you can do and still keep it street legal and drivable in normal traffic, visit your local speed shop or check around online, I was never one for the Edlebrock crowd I didn't want mine to look like everyone else's engines.
Well, finally the thing that I was originally posting this posting for... The Chevy Small Block will take either the Turbo 350 or the 400, they will both bolt right on, but, the tail shaft is different so if possible get the drive shaft that was mated to the tranny you will need the yoke to convert your existing drive shaft unless it is already setup for the '350.
