Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 09-16-2007, 07:06 PM
liquidflame1 liquidflame1 is offline
96 skylark i'm getting code P0420
Hello all, I'm getting code P0420 catalyst efficiency below threshold (bank1)
is this an o2 sensor code???
Old 09-26-2007, 07:00 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 96 skylark i'm getting code P0420
To generate the P0420 DTC the 02 sensor is most likely working. On odb-ii cars the rear, post CAT convertor 02 sensor. It means your CAT has less than desireable oxygen storage capability. In most cases it is a bad CAT convertor.
Timeslip 08/12/06
AF Community Guidelines
Old 09-29-2007, 02:11 PM
Blue Bowtie's Avatar
Registered Offender
That's probably true on Buicks, but on Bonneville versions of the W-Body, I've had several P0420 DTCs on cars with weak rear O² sensors. Many years had a heated rear and non-heated front sensor. I'm not sure if the '96 was that way or not, but '98 Bonnies were like that.
Old 09-29-2007, 02:55 PM
BNaylor's Avatar
On this particular Buick model regardless of whether he has the 3.1L V6 or 2.4L L4 both of the 02 sensors are heated.
Timeslip 08/12/06
