Old 09-16-2007, 06:41 PM
chase82 chase82 is offline
Trans identification/serial numbers
Where can I go/ or how do I decode the transmission numbers to determine what year it is? Thanks guys/girls.
Old 09-16-2007, 09:36 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Trans identification/serial numbers
Theres a VIN number on the trans. Decode the VIN to tell what year it came from
Old 09-16-2007, 10:02 PM
Ya I've got that far..lol..I have the numbers, I'm wondering how do I decode them.
Old 09-16-2007, 11:11 PM
Stealthee's Avatar
http://ypass.net/3s/story.php
Old 09-17-2007, 02:12 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
http://stealth316.com/2-engtranyids.htm
give me the full transmission code and i'll cross reference it with the service manual and tell you what year it came out of. i'd copy the info now, but i gotta run. i'll post it later.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 09-17-2007, 04:36 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
or just post the vin and I will tell you what it came out of
Jason
Old 09-18-2007, 04:58 PM
great...I think i recorded the part number instead of the VIN...F4A331MN01 / BU6927
Thanks for everyones help.
Old 09-18-2007, 07:00 PM
Linebckr49's Avatar
well its an Automatic 4 speed from a 3000GT, but i couldn't find anything matching MN01. lots of similar codes, but not that one in particular. it just denotes which year the transmission is from.
post up your VIN and Jason_bet can tell you everything. however, if your transmission is not the original one that came with your car, then there's not much more we can do.
93 3000GT base
Old 09-18-2007, 08:40 PM
Thanks for all your help guys! I will try to get the VIN off in a couple days. I have a 91 stealth and put in a new trans which is newer so I have to change the intermediate shaft and pass. axel. I ordered a 93 3000gt shaft and axel so I'm hopeing it works. I'm guessing the trans isnt newer than 96 so I think i'm ok.
