Old 09-16-2007, 05:52 PM
slyone05 slyone05 is offline
ignition wiring
My ignition on my 98 jimmy has been messed up and the key wont kick off. Does anyone know what the green and white wire works. That is the wire that is dead and wont let the key kick all the way off. I put a jumper wire on it and the key will kick back all the way off, but it has no power through it. Will that cause a po753 code and no shifting into second gear?
Old 09-16-2007, 08:51 PM
82Stang 82Stang is offline
Re: ignition wiring
I've heard a PO753 is an issue that may be resolved by:
- replacing solenoid A in the tranny OR
- getting a new computer
Hope this helps.
Old 09-17-2007, 07:18 AM
Re: ignition wiring
I have replaced the solenoids and the wiring harness in the transmission, but it could be the computer, dont really know, thought it might be the ignition wiring.
Old 09-18-2007, 06:01 PM
Re: ignition wiring
Have you checked any fuses and relays for the ignition? Or how about the tumbler itself malfunctioning?
Old 09-19-2007, 05:32 PM
Re: ignition wiring
Ive checked all the fuses in the whole truck.
Old 09-19-2007, 05:36 PM
qwerll qwerll is offline
Re: ignition wiring
does anyone know anything about batteries
Old 09-19-2007, 05:37 PM
Re: ignition wiring
because i hooked up a positive pole with a negative pole while giving my car a boost and it wont start again
Old 09-19-2007, 05:51 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: ignition wiring
You need to start anew post on your problem.
Give year and engine.
In the mean time check all fuses and fuse links and power feeds.
MT
Old 09-19-2007, 05:52 PM
Re: ignition wiring
Thanks for your help, sorry bout just putting my problem out there in this post, thanks again
Old 09-19-2007, 05:54 PM
MT-2500's Avatar
AF - Advisor
Re: ignition wiring
No problem.
Hit the New thread button upper left side of page.
MT
MT
Old 11-08-2007, 08:58 AM
Re: ignition wiring
fixed it new computer
