Go Back   Automotive Forums Car Chat > Ford > Contour
Old 09-16-2007, 05:00 PM
Slicc87 Slicc87 is offline
Gearbox
I am hearing a grinding noise and it sounds like gears almost like a roller coaster sound. When I put the gearshift into reverse it sounds real loud. I am thinking it might be the gearbox. Has anybody ever had this problem and if so how much would it be to fix?
Old 09-16-2007, 05:30 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: Gearbox
Its going to cost $1256.87.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 09-16-2007, 05:32 PM
Re: Gearbox
Ok, seriously though...
Nobody is going to tell you how much it is to fix since all we know is your car makes a horrible noise. I cant even guess that one on the description.
What transmission do you have?
Does the car still drive with it in gear?
Does it only make noises when in gear?
"The CEG Nazi"
www.contour.org
Old 09-17-2007, 09:40 AM
Re: Gearbox
It's an automatic. It does drive when in gear and it does make noise when driving. Ever had this problem or know anybody with the same problem. I'd like to nip this in the bud as soon as possible because if not then it can get worse and end up costing me a fortune to replace the tranny.
Old 09-17-2007, 11:38 AM
Re: Gearbox
Does it make the noise when in gear and sitting still?
"The CEG Nazi"
www.contour.org
Old 09-17-2007, 09:58 PM
Re: Gearbox
Yeah. Not real loud but definately noticeable if the radio is off and you are listening for it.
Old 09-18-2007, 08:06 AM
Re: Gearbox
Well, its either transmission related or some sort of vibration issue. I would get underneath the car with the car running and see exactly where the noise is coming home. Maybe its just a heat shield loose thats rubbing up against some bolts. I know one guy had some 'grinding' issues that turned out to be that. If its coming from inside the trans, your looking at probably at least $1000 to fix, since pulling these transmissions aren't fun.
"The CEG Nazi"
www.contour.org
