Old 11-24-2002, 07:23 AM
romabimmer's Avatar
romabimmer romabimmer is offline
Exclamation Vehicle Brake Information (very long)
My Technical Website on Brake Systems
Brake Performance
I want to make it clear there is a difference between making a brake system feel better and actually perform better.
Brake Performance: Level of brake torque produced and the resistance to brake torque loss, better known as fade.
Brake Torque=Fluid Pressure*caliper piston area*pad coefficient of friction*effective rotor radius
-For piston area multiply area by 2 for sliding calipers, rotor radius is measured from center of rotor to the center of the pad
*effective radius is the distance from the center of the hub to the center of the brake pad
For performance I do not use the term stopping distance because that involves more than just the brakes.
Basically, you need a bigger rotors and good pads with the best contact patch possible between the two. Also higher friction levels with higher mu brake pads.
And most importantly.........REALLY GOOD TIRES!
And you need a way to get rid of that heat at a faster rate. More rotor mass and/or better conduction (vented, etc.).
How a car stops is simple, it takes Kinetic Energy (energy created by motion) and transfers it to Heat (Thermal) Energy. It does this by the mechanism of friction.
KE=1/2 the mass of the vehicle multiplied by the square of it's velocity
Brake Power is determined by the rate of KE to TE transfer, or also know as WORK.
Simply, to stop sooner you need to transfer Kinetic Energy into Heat Energy faster.
There are no other tricks; you need higher levels of friction and ways to dissipate the heat quicker.
The big things to do to get shorter stopping distance:
1. Best Tires for the conditions (use common sense here, no Pilots in Feb in Alaska)
2. Higher Friction Brake Pads and/or rotors
3. Larger effective radius
4. Calipers with more piston area
The other things you can do that give you that extra advantage:
1. LOSE WEIGHT (the car I mean), less mass, less KE
2. Minimize rotational inertia of wheels/tires. Get lighter wheels and tires (all else being equal). Note: the farther away from the center of rotation the mass is the great the inertia, so a 17" wheel will have greater inertia than a 16" all else being equal.
3. Try and balance out the braking, if the rears can do more work it spreads out the work. Less weight transfer to the front BY MOVING THE BATTERY TO THE TRUNK, stuff like that.
4. Practice! Get to know how your system works so you can best utilize it.
5. Don't drive to fast, remember it the square of the velocity. The amount of KE increase from 40KPH to 80KPH is not 200%, but 400%
The formula below is a decent way to estimate what, if any, increase you have in brake torque after an upgrade:
Brake Torque Increase %=
[(caliper piston area new/old) * (effective radius new/old)* (brake pad friction coefficient new/old)]
*For sliding calipers multiply the areas by 2
Any answer equal to 1 means no increase. Any answer less than 1 means you've gone backwards. Any answer greater than 1 means a torque increase.
This will NOT give you the actual brake torque, just the difference.
Things like 2-piece rotors, cross-drilling, slotting, cryogenics, heat-treating are all "at limit" technologies. In other words they only make a noticeable difference (if any) at the very limits. If you drive on the street in a manner that actually utilizes these technologies regularly you're probably dead and not reading this!
Brakes are as much art as science, there are just so many different variables involving not only performance but also feel and consumer wants it becomes a real pain!
Again, you have to know what you want to get out of your system and where you're going to use it.
In the end if you got the cash it won't hurt, but you get to a point of diminishing returns and you have to wonder!
Brake Fade
Brake fade: the loss of brake torque due to items other than mechanical failure
Basically, fade is caused by over use of the brakes to the point where a majority of the fluid pressure and/or pad friction is lost.
This is caused by heat, as heat is created in the brake system it causes the brake fluid to boil and that introduces air into the system. If enough brake fluid is transformed into a gas you will not be able to create the required brake pressure to stop the vehicle.
On top of this the same heat causing the fluid to boil is also breaking down the pad and dropping it’s coefficient of friction. This is commonly referred to as pad fade.
To avoid fade is very easy, you can use a fluid with a higher boiling point and/or a pad with a more advantageous temperature vs. coefficient of friction curve. You can also introduce cooling into the system with brake air ducts, vented rotors, rotors with more vent surface area and overall better ventilation in the corner area.
Also, venting built up gases under the pad was a big problem, but pad tech has come so far that it's not something I would worry about (assuming your using race pads for racing). Again it's one of those things that are there but only makes a very, very, very minor difference (if any) most of the time.
Stopping Force Calculations
Equations:
(for ease and consistency try and use meters and kg)
NOTE: Equation 1 does not mean more weight you have more stopping force, it is just to calculate the stopping force required. As you can see in Equation 8, the larger the stopping force is the larger and more aggressive the brakes need to be.
1.
stopping force total = weight of car * longitudinal coefficient of friction of tires
2.
Front Force = (weight front + total weight) * tire friction * height of CG * (1/wheel base)
3.
Rear Force = (total weight - rear weight) * tire friction * height of CG * (1/wheel base)
4.
% front = Front Force/Stopping Force
5.
% Rear = Rear Force/Stopping Force
6.
Area of Master Cylinder * pedal ratio = M
Area of front or rear piston= N
Mechanical Force Ratio= M/N
7.
mechanical force ratio front = mechanical force ratio * %front
mechanical force ratio rear = mechanical force ratio * %rear
8.
Stopping Force = pedal force * brake pad coefficient of friction * mechanical force ratio * (1/radius of the tire) * brake rotor effective radius
.....solve for the parameter you need
Brake Air Ducts
This is only for auto-x and racing.
Getting all that extra air on the brakes going down a straight gets the brakes nice and cool for the next corner.
Cheap and effective way to keep rotor temperatures down and therefore reduce fade.
Rear Brakes
Just want to add a little warning about the rear brakes. Be VERY careful when it comes to making changes back there. Upgrading the rears to increase braking power, not just feel, can be a double-edged knife.
More braking power to the rears will only do you well if; 1. the balance is woefully off and the rears are under-utilized, if you can easily lock-up the rears your already at full potential or 2. you have increased the weight the rear tires carry, the grip of the rear tires and/or minimized the weight transfer to the front.
Putting more powerful brakes on the rear alone does nothing more than cause you to lock up or go into an ABS event sooner. You must increase the rear tire’s load to benefit from an increase in the rear brakes power. Otherwise, the rears should be looked at only from a "feel" standpoint.
Old 01-17-2003, 01:24 PM
romabimmer's Avatar
Exclamation Pedal Feel
Pedal Feel
First some quick definitions: Brake Pedal ratio is the measurement of how much mechanical assistance you are getting from the pedal. Example: a ratio of 4.1 will give you 41 pounds at the booster input rod for a 10 pound load at the pedal itself.
Dead or lost travel is how much pedal stoke is required before you actually start stopping.
Dead Travel or Lost travel and overall poor pedal feel is made up of the following:
[(Travel as measured at the brake service pedal assembly pin (where the booster connects)]
(Imagine traveling from the pedal through the brake system to the rotor, all lost travel must be multiplied by whatever your brake pedal ratio is.)
1. Tolerance between brake pedal pin and booster input rod. This can be quite a bit for systems that use a pin mounted brake light switch. If you do have such a switch do not remove it or take up the slack as your brake lights will be on all the time. If you don't have a pin-mounted switch just get a tighter bushing. If you do, you're out of luck.
* will be felt during first few mm of travel
2. Slack in the brake pedal assembly itself. To see how good or bad yours is, with the car off pump the brakes until hard (2-3 pumps) and then grab the pedal with your hands and see how much it moves around.
* will be felt through first few mm of travel (I hope)
3. Dash flex. This can range dramatically from vehicle model to vehicle model. Not much you can do about this.
*felt during medium and high decelerations stops on most cars, on Fords dashes flex with the breeze
4. Lost travel in booster. This is designed to be there to allow for booster expansion due to climate and use over time. Only adds half an mm (multiplied by the pedal ratio).
*felt only in the first few mm of travel
5. Flex of booster shell. Can be a real problem on some designs. All you can do is try and brace the booster or replace with a better product.
*felt on medium and high deceleration stops
6. Design tolerances in the Master Cylinder. Varies greatly from one to another. Simply, if you want less lost travel in the TMC (tandem master cylinder), you have to pay for a more expensive one. A minimum lost travel of about 1-1.5mm is required for proper and safe operation. However, I've seen some with double that. (Again multiplied by the pedal ratio)
*felt during first 10mm or so of pedal travel
7. The brake tubes and ABS unit. Maybe .0000001mm here. Don't worry about it.
8. Brake hoses. Get steel braided ones, there worth it. Rubber hoses flex quite a bit under pressure.
*felt almost all the time
9. Brake Caliper Piston Roll Back. This is usually the worst offender. Only way to get rid of this is to get better calipers. Roll back is how far the piston moves away from the rotor when pressure is released. The bigger the gap, the more you have to push on the pedal to get contact.
10. Caliper Deflection. The caliper actually flexing under pressure, like 9 you can only improve this with better calipers.
*felt during medium and high deceleration stops
11. Brake pad backing plate. If this is flimsy it will flex and not allow a good contact between the rotor and pad forcing you to apply more pressure and therefore more pedal travel. Fixed by replacing pads with higher quality ones.
*felt most of the time
12. Brake pad material itself. If the material is low density it will compress like a sponge. And if it's a low mu (friction) pad it will require more pressure and therefore more pedal travel.
*felt all the time
13. Rare, but a problem on really cheap brake pads: The bonding process used to bond the brake pad material to the backing plate. A poor process will cause the material to "squirm" around.
Well those are the biggies, but not the biggest. The biggest is AIR in the system. Before you do anything else do a really good and thorough brake bleed. And only use the fluid it says to use on the cap, DOT 3 or DOT 4 or whatever.
Also, changing the brake pedal assembly to one with a lower ratio. Remember all lost travel is multiplied by the pedal ratio, the lower the ratio the less dead travel at the pedal pad. This also firms up the pedal as you're getting less mechanical assistance. Just be careful, because if you're brake booster fails it will take more force on the pedal to come to a stop.
Pedal feel can also be "tuned" with a different booster.
Cut-in is what sets the initial point of boost (when it kicks in)
2-stage (knee height) is what sets how much initial force
Boost ratio is just as it sounds, it sets how much assist you get
Run-out is the maximum assist
Brake Feel and it’s Benefits
Brake feel: pedal effort and pedal travel for any given desired deceleration. Ease of brake pressure modulation, accuracy and precision of modulation. Feedback through the pedal "describing" pad rotor contact dynamics and pressure fluctuations.
The stopping distance of a car is not necessarily directly related to the feel. A poor feeling brake system can have very good performance, i.e. Jaguar. While a great feeling system can have lousy performance, i.e. Ford Focus
Benefits of "better" feel:
Brake feel is just like steering feel. The better the feel/feedback is the more of the inherent performance you will actually be able to use.
Imagine a car that has 1.0g of lateral grip, but has lousy steering. Too light, completely dead, nothing happens just off-center, poor linear response and too much or too little ratio.
How much of that great 1.0g are you ever going to be actually using with poor steering?
Same with brakes. Improving feel will allow you to better use what you have.
However, it will not objectively increase brake performance. If you are already getting the max out of you system then better feel will not get you more.
Things like steel lines, stiffer calipers affect feel, not performance. Only force applied, torque arm and friction do that. You can change things like lines, calipers, pedals and boosters to change the characteristics. Such as, initial bite point and initial deceleration level, pedal travel and effort, pedal force multiplication. However, these do not actually produce more brake torque.
What master cylinder and caliper sizing means to pedal feel
Here is how to calculate mechanical advantage:
Area of MC * pedal ratio = M
Area of front piston= N
ME= M/N = larger is less effort
(MC-master cylinder)
A larger MC results in...
* less pedal travel
* a higher effort pedal
* less hydraulic advantage
* Works well on vehicles that have high fluid volume requirements since you can get plenty of flow with reasonable pedal travel. Large bore master cylinders tend to give less “feedback” and a somewhat isolated feel.
A smaller MC results in...
* more pedal travel
* a lower effort pedal
* more hydraulic advantage
* Works well in lighter vehicles where fluid volume requirements is low and excessive pedal travel is not a concern. Small bore master cylinders tend to give better “feedback” and less isolation from the system.
Typical TMC, Tandem Master Cylinder and most common design used
Calipers:
Larger caliper piston area results in...
* more pedal travel
* a softer pedal
Smaller caliper piston area results in...
* less pedal travel
* a firmer pedal
Stainless Steel Braided Brake Lines
SS lines will NOT improve braking distance.
What will SS lines do? They will firm up the pedal and will shift the braking pedal feel curve. The later means that you will reach braking force earlier in the pedal stroke than without the SS lines.
Anyway, SS lines do technically firm up the pedal through out the brake pedal stroke. But the difference may not be noticeable all the time.
SS lines almost always make a difference at braking events at or over 0.25g, this is equivalent to the kind of hard braking you see when driving back roads in an aggressive manner. Regular rubber brake hoses will flex initially under high pressure, this is a volume loss that is expressed as dead travel at the pedal.
With SS lines the harder you push on the pedal the more the level of the improvement felt.
Old 01-17-2003, 01:25 PM
romabimmer's Avatar
Lightbulb Brake Fluid and Bleeding
All brake fluids absorb moisture, some faster than others (except silicone which is not recommended for anti-lock brake systems). Castrol SRF resists moisture contamination (non-hygroscopic) more than any other fluid we tested; therefore change intervals can be greatly extended. This reduces the effective cost over a season of racing. Many drivers say that they can run the same fluid all year long with only bleeding off the fluid in the calipers for each event. This way a can or two will last all year. Other fluids (hygroscopic type) require additional flushing of the system for each track event to maintain the lowest percentage of moisture and the highest boiling point.
FYI - The Castrol SRF is around $77/container versus $10-15/container for the rest.
Silicone Brake Fluids
Fluids containing Silicone are generally used in military type vehicles and because Silicone based fluids will not damage painted surfaces they are also somewhat common in show cars.
Silicone-based fluids are regarded as DOT 5 fluids. They are highly compressible and can give the driver a feeling of a spongy pedal. The higher the brake system temperature the more the compressibility of the fluid and this increases the feeling of a spongy pedal.
Silicone based fluids are non-hygroscopic meaning that they will not absorb or mix with water. When water is present in the brake system it will create a water/fluid/water/fluid situation. Because water boils at approximately 212º F, the ability of the brake system to operate correctly decreases, and the steam created from boiling water adds air to the system. It is important to remember that water may be present in any brake system. Therefore silicone brake fluid lacks the ability to deal with moisture and will dramatically decrease a brake systems performance.
Brake Fluid and Cold Temps.
Kinematic viscosities: All brake fluids (DOT 3, DOT 4 and DOT 5) must meet a minimum viscosity test of not less than 1.5 centistokes at 100° C (212° F) and must not be more than the following to meet their various classifications (the larger numbers indicate higher kinematic viscosities just like with motor oils).
DOT 3 1500 Centistokes at minus 40° C
DOT 4 1800 Centistokes at minus 40° C
DOT 5 900 Centistokes at minus 40° C
Higher kinematic viscosities means it "flows easier" at the cold temps.
A centistokes is 1 mm^2/s
MINIMAL boiling points for these specifications are as follows:
|| Dry Boiling Point || Wet Boiling Point
DOT 3 || 401ºF || 284ºF
DOT 4 || 446ºF || 311ºF
DOT 5 || 500ºF || 356ºF
DOT 5.1 || 518ºF || 375ºF
Poly Glycol Ether Based Brake Fluids
Fluids containing Poly glycol ethers are regarded as DOT 3, 4, and DOT 5.1. These type fluids are hygroscopic meaning they have an ability to mix with water and still perform adequately. However, water will drastically reduce the boiling point of fluid. In a passenger car this is not an issue. In a racecar it is a major issue because as the boiling point decreases the performance ability of the fluid also decreases.
Poly glycol type fluids are 2 times less compressible than silicone type fluids, even when heated. Less compressibility of brake fluid will increase pedal feel. Changing fluid on a regular basis will greatly increase the performance of the brake system.
FLUID SPECIFICATIONS All brake fluids must meet federal standard #116. Under this standard are three Department of Transportation (DOT) minimal specifications for brake fluid. They are DOT 3, DOT 4, and DOT 5.1 (for fluids based with Polyalkylene Glycol Ether) and DOT 5 (for Silicone based fluids).
Wet vs. Dry Boiling Point
WET BOILING POINT - The minimum temperatures that brake fluids will begin to boil when the brake system contains 3% water by volume of the system.
DRY BOILING POINT - The temperatures that brake fluid will boil with no water present in the system.
How does water get in there?
Water/moisture can be found in nearly all brake systems. Moisture enters the brake system in several ways. One of the more common ways is from using old or pre-opened fluid. Keep in mind, that brake fluid draws in moisture from the surrounding air. Tightly sealing brake fluid bottles and not storing them for long periods of time will help keep moisture out. When changing or bleeding brake fluid always replace master cylinder caps as soon as possible to prevent moisture from entering into the master cylinder. Condensation, (small moisture droplets) can form in lines and calipers. As caliper and line temperatures heat up and then cool repeatedly, condensation occurs, leaving behind an increase in moisture/water. Over time the moisture becomes trapped in the internal sections of calipers, lines, master cylinders, etc. When this water reaches 212º F the water turns to steam. Many times air in the brake system is a result of water that has turned to steam. The build up of steam will create air pressure in the system, sometimes to the point that enough pressure is created to push caliper pistons into the brake pad. This will create brake drag as the rotor and pads make contact and can also create more heat in the system. Diffusion is another way in that water/moisture may enter the system.
Diffusion occurs when over time moisture enters through rubber brake hoses. The use of hoses made from EPDM materials (Ethlene-Propylene-Diene-Materials) will reduce the amount of diffusion OR use steel braided brake hose with a non-rubber sleeve (usually Teflon) to greatly reduce the diffusion process.
DOT what?
DOT: Acronym for "Department of Transportation" -- an American federal agency or "Department of Transport" -- a British agency
DOT 3: This brake fluid has a glycol base. It is clear or light amber in color. Its dry boiling point is 401° minimum and wet boiling point of 284° minimum. It will absorb 1 to 2 percent of water per year depending on climate and operating conditions. It is used in most domestic cars and light trucks in normal driving. It does not require cleaning the system and it can be mixed with DOT 4 and DOT 5.1 without damage to the system. The problem with it is that it absorbs moisture out of the air and thereby reduces its boiling point. It can also damage the paint on a vehicle.
DOT 4: This brake fluid has a borate ester base. It is clear or light amber in color. Its dry boiling point is 446° minimum and wet boiling point of 311° minimum. It is used in many European cars; also for vehicles in high-altitude, towing, or high-speed braking situations, or ABS systems. It does not require cleaning the system and it can be mixed with DOT 3 without damage to the system. The problem with it is that it absorbs moisture out of the air and thereby reduces its boiling point. It can also damage the paint on a vehicle.
DOT 5: This brake fluid generally has a silicone base. It is violet in color. Its dry boiling point is 500° minimum and has no wet boiling point in federal DOT 5 specifications. It is used in heavy brake applications, and good for weekend, antique, or collector cars that sit for long periods and are never driven far. It does not mix with DOT 3, DOT 4, or DOT 5.1. It will not absorb water and will not damage the paint on a vehicle. It is also compatible with most rubber formulations. The problem with it is that it may easily get air bubbles into the system that are nearly impossible to remove, giving poor pedal feel. It is unsuitable for racing due to compressibility under high temperatures. If as little as one drop of water enters the fluid, severe localized corrosion, freezing, or gassing may occur. This can happen because water is heavier and not mixable with silicone fluids. It is unsuitable for ABS.
DOT 5.1: This brake fluid has a borate ester base. It is clear or light amber in color. Its dry boiling point is 500° minimum and wet boiling point of 356° minimum. It is used in severe-duty vehicles such as fleets and delivery trucks, towing vehicles, and racecars. It can be mixed with DOT 3 or DOT 4 without damage to the system. It maintains higher boiling point than DOT 3 or DOT 4 fluids due to its higher borate ester content. It is excellent for severe duty applications. The problem with it is that it costs more than other fluids and there is limited availability. It also absorbs moisture out of the air and thereby reduces its boiling point. It can also damage the paint on a vehicle.
What causes a mushy pedal?
DOT 5 fluid is not hygroscopic, so as moisture enters the system, it is not absorbed by the fluid, and results in beads of moisture moving through the brake line, collecting in the calipers. It is not uncommon to have caliper temperatures exceed 200° F, and at 212° F, this collected moisture will boil causing vapor lock and system failure. Additionally, DOT 5 fluid is highly compressible due to aeration and foaming under normal braking conditions, providing a spongy brake feel.
Brake Bleeding/Flushing
One thing that is ALWAYS true never let the TMC (master cylinder) on an ABS, traction control (TCS) or electronic stability program (ESP) car run dry. You'll never get the air bubbles out again by hand. To be honest there is more than one right way and if you found something that works, why fix what's not broken.
Just FYI-
At the factory this is how it's done. They do it all one shot.
First you mount the Evac-Fill head unit to the reservoir then all air is evacuated from the system, creating a vacuum. Then fluid is forced through the system at high pressure.
Then the car is delivered and people complain about mushy pedal!
Just some more stuff:
I e-mailed a Tech at Ford I used to work with on the proper bleed sequence. Since techs do these all the time and engineers don't I'll take his advice.
This is it:
Doing nearest or most distant doesn't matter. What matters is if the brake system is a diagonal or front-rear system.
Quick definition: diagonal means that one circuit in the master cylinder feeds the front driver's side and the rear passenger side. The other circuit the front passenger's and rear driver's. Both circuits are of equal volume. Front-Rear means that one circuit supplies the front calipers, while the other the rear calipers. The Primary circuit (front caliper circuit) is of greater volume.
All you need to do is make sure you do the circuits together. For instance, on most passenger cars it's a diagonal system. So you want to do the driver's front and passenger's rear together, which you do first is not all that important. But he does agree that the tradition is to do the rear first. Or best to get a friend and do both at the same time. And take your time (he told me to make sure I added this).
Same holds true for the Front-Rear systems. Do fronts together and rears together. Usually only trucks, SUVs and very heavy front bias cars (Ford Crown Vic) have a Front-Rear system.
Just FYI- Diagonal is used so that if one circuit fails the vehicle is still stoppable in a stable manner as at least one front and rear wheel is braking and on opposite sides. Front-Rears are used on heavy, front-bias cars require a lot of volume up front.
ABS Bleeding:
Do 3 normal bleeds and then do
An ABS stop if you still feel that air might be trapped. Then do 1 more
Bleed. The ABS stop would have flushed the air out.
Old 01-17-2003, 01:26 PM
romabimmer's Avatar
Electronic Brake Aids
Anti-Lock Brakes and Electronic Brake Distribution
Please go to this website: http://www.geocities.com/nosro/abs_faq/
It’s an excellent explanation of Electronic Braking Aids
Electronic Stability Control (ESP)
Be aware that the technology is marketed under a number of different trade names
Audi: Electronic Stability Program (ESP). BMW: Dynamic Stability Control (DSC). DaimlerChrysler: Electronic Stability Program (ESP). Ford Motor Company: Advance Trac. General Motors: Active Handling System (Corvette), Stabilitrak (Pontiac, Cadillac). Jaguar: Dynamic Stability Control (DSM). Lexus: Vehicle Skid Control (VSC). Porsche: Porsche Stability Management (PSM). Volkswagen: Electronic Stability Program (ESP). Volvo: Dynamic Stability Traction Control (DTSC).
Note: This technology is moving so fast that it will be obsolete before you finish reading this paper
Components in Bosch's ESP system. They include A) active wheel speed sensors;
B) steering angle sensor; C) combined yaw rate sensor/lateral accelerometer;
D) attached electronic control unit (ECU); E) motor; F) pressure sensor, and
G) hydraulic unit. (Photo courtesy of Robert Bosch Corporation) *Some systems use ride height sensors.
Introducing Stability Control
So how does stability control differ from the traction control systems currently on the market? Essentially, traction control acts on a vehicle's drive wheels to prevent unwanted wheel spin under acceleration. While this helps in low traction situations such as snow or rain, traction control's ability to assist in more extreme emergency situations is limited. A stability control system, on the other hand, goes one step further by actually detecting when a driver has lost some degree of control. It then automatically stabilizes the vehicle to help the driver regain control.
The "it" of this scenario is a complex system of sensors and microprocessors that continually monitors the vehicle for any signs of instability. Once detected (usually in the form of a slide or skid), the system automatically applies selective braking to specific wheels thereby stabilizing the vehicle. This split-second intervention often happens so quickly it's over before drivers even realize they were in danger of losing control.
ESP is applicable for both front-wheel drive, rear-wheel drive and four-wheel drive vehicles. For instance, front-wheel drive vehicles can commonly encounter understeering in cornering at high speeds or in emergency steering maneuvers to avoid accidents. With understeering, the front wheels push the vehicle toward the outer edge of a turn. By contrast, at higher speeds rear-wheel drive vehicles typically can be oversteered, which means the vehicle responds to the driver's steering and the rear wheels slide outward.
With ESP, sensors control braking separately at all four wheels and can also reduce engine torque to lower the speed and help maintain stability. For example, if the driver oversteers and the rear wheels begin to slide outward, ESP's computer counteracts by braking the outer front wheel, creating an opposing and stabilizing yaw force and by reducing engine power, if necessary. If the driver already has applied the brakes while cornering, the ESP control computer will boost the brake pressure at the front wheel that is on the outside of the turn and reduce brake pressure on the inner front wheel. If the driver encounters understeer, ESP brakes the rear wheel on the inside and helps bring the car onto the required course.
What Makes it Tick?
All the enhanced stability systems currently being marketed by manufacturers such as BMW, Cadillac, Chevrolet, Lexus, and Mercedes-Benz approach vehicle stability in similar ways.
The heart of all these systems is a central processor that takes information from a number of sensors, and then determines whether the car is in a stable or unstable state. By combining the data from ABS sensors (for wheel speed), steering angle sensors, yaw sensors (measuring the amount a car fishtails, or rotates around its vertical center axis), and lateral force sensors (measuring the amount of sideways g-force generated by the car), the central processing unit can actually detect when a vehicle is behaving in a way contrary to how the driver intends.
If the processor does detect instability such as a slide produced by a sudden swerve, it automatically applies light brake pressure to a select wheel (or wheels) to maintain or restore control. On some systems such as the BMW Dynamic Stability Control III and the Porsche Stability Management system, engine torque is also automatically decreased to aid in the stabilizing process.
The Stability System at Work
The most common types of slides are referred to as understeer and oversteer. In an understeer situation, the front of the car plows toward the outside of a turn without following the curve of the turn. When the stability control system detects understeer, it applies light brake pressure to the inside rear wheel. This helps "tug" the front of the car back onto the intended line.
In an oversteer situation, the rear of the car fishtails toward the outside of a turn, increasing the chance of a spin. To counteract such a situation, the stability system applies braking to the outside front wheel, bringing the rear end back in line.
On most vehicles, a warning light on the dashboard illuminates when the system is operating. In the case of the Lexus Vehicle Skid Control system, a subtle audio signal also sounds .
When Does it Help?
Like the safety systems that preceded it, stability control is designed to step in when human input is incapable of effectively controlling the vehicle. In most cases, critical situations are the result of human error in the first place driving too quickly for conditions, inattention, misjudgment or simply panicking in an emergency situation.
But no matter how advanced the safety aid, never forget that the ultimate fate of a vehicle and its occupants remains in the hands of the driver. No safety system should ever be expected to protect unconditionally. So while the latest generation of stability control systems offer drivers increased protection from both themselves and the unexpected, they can never overcome poor judgment or the laws of physics.
The next step is pure “brake-by-wire” and the future is now. Mercedes SL has a system where the pedal is a switch with no direct connection to the brake system.
Dynamic Brake Control
Is a "Panic Assist Feature" what it does is measure the velocity of pedal travel by using either a sensor on the pedal or in the booster. If a certain threshold is met then the booster (if it's an electronic booster) or the DSC pump will apply max pressure. It doesn't actually stop the car in any shorter distance than you could.
The reason for DBC is that it's been established than many people when emergency braking will ease off the brake pedal a little after the initial stab. DBC keeps the pressure up even if you let off. This can be a real pain when your trying to modulate the brakes yourself as most systems have a pretty low threshold and just aggressive braking is seen as a "panic stop."
This feature also requires a functioning ABS, the expensive systems are electronic so if the ABS fails the feature is disabled, but some cheaper cars have a purely mechanical system and a failed ABS is not detected. You can imagine what happens when you have max brake power and no ABS.
Old 01-17-2003, 01:27 PM
romabimmer's Avatar
Lightbulb Brake Components
Brake Calipers
The caliper’s basic function is to force the pads against the rotor. A caliper is made of 3 basic groups, the housing (body), the pistons and the mounting bracket. The pistons sit in the housing and are the components that directly push the pads against the rotor. The housing is there basically to hold and flow fluid to the pistons and give the piston somewhere to live.
There are 2 families of calipers, the sliding caliper and the fixed caliper:
The sliding caliper is by far the most common and is mostly likely what’s on your car. It has pistons only on the inboard side and the caliper slides on guide pins to force the outside pad against the rotor.
The fixed caliper has a single (monobloc) or 2 piece bolted housing and piston(s) on both the outboard and inboard side. The caliper is completely stationary and each side applies pressure to the pads independently.
What’s the difference? The major differences between the fixed and sliding calipers is weight and stiffness. A fixed caliper in general weighs less and has significantly less flex. This means better pedal feel. Fixed calipers also tend to have a lower profile allowing a larger rotor in the same wheel. Advantage of a sliding caliper is cost, they are usually much less expensive.
Single piston and multi-piston Calipers:
Most sliding calipers are of the single piston type, which means one large piston does all the work. Dual-piston calipers are becoming more popular. Most fixed calipers are 4 piston type, 2 pistons on each side. There are 2 piston fixed and some go as high as 8 pistons total. The advantages of multiple pistons is:
1. More piston area more force on pad and you can fit more piston in any given rectangle with smaller diameter pistons (like engine valves in the heads).
2. A lower profile caliper as 2 small pistons have a “lower height” than one big piston. This means less flex since the distance from the point of application to the bridge (top strap) of the caliper is less.
More pistons usually adds more cost and low force braking feel is softer.
Cross-drilled and Slotted Rotors
Cross-drilled rotors:
Disks that have been drilled through with a non-intersecting pattern of radial holes. The objects are to provide a number of paths to get rid of the boundary layer of out gassed volatiles and incandescent particles of friction material and to increase "bite" through the provision of many leading edges. The advent of carbon metallic friction materials with their increased temperatures and thermal shock characteristics ended the day of the drilled disc in professional racing. They are still seen (mainly as cosmetic items) on motorbikes and some road going sports cars. Typically in original equipment road car applications these holes are cast then finished machined to provide the best possible conditions by which to resist cracking in use. But they will crack eventually under the circumstances described in another section (see Cracking). Properly designed, drilled discs tend to operate cooler than non-drilled ventilated discs of the same design due the higher flow rates through the vents from the supplemental inlets and increased surface area in the hole. That's right, inlets, the flow is into the hole and out through the vent to the OD of the disc. If discs are to be drilled, the external edges of the holes must be chamfered (or, better yet, radiused) and should also be peened.
Slotted:
Shallow, sharp edged but radiused bottom grooves milled into cast iron discs to provide leading edges for bite and a path for the fire band of gases and incandescent friction material to be dissipated through. If the slots fill up with pad material, the system is operating at too high a temperature.
For the track they work. Not as dramatically as the ads will lead you to believe, but they do a good job of keeping the pad surface "clean" when they get really hot and they do a good job of venting gases. Again though, with modern pads neither of the issues mentioned are that severe now a days.
2-Piece rotors
I have seen a lot on 2-piece rotors. Some of the information contained in them is correct some is mythical.
Some definitions.
2-Piece rotor: A brake disc rotor that has a separate hat (cap) usually made from a lightweight metal. There are two types of common 2-piece street rotors. One uses a bolted hat and the other a pinned hat (also known as a "floating rotor" design).
The bolted type is just what it sounds like. Usually an aluminum hat bolted to a cast iron rotor. The only real benefit of this design is weight savings. However, weight savings tend to be only 10-20%, all else being equal, but with a 50-75% price increase.
The pinned type has usually stainless steel pins that attach the aluminum hat to the rotors. This allows the rotor to "float" on the pins. The great advantage of this design is that it allows the rotor to move freely. When the rotor expands and contracts there is much less chance of binding or distortion. As you can imagine this cuts down on warping and uneven wear (DTV). The disadvantage of this design is really high costs and increased NVH.
As far as better heat conduction, not really. It does help a bit, buts it's not enough to make it worth the extra cost. The nice think about the weight savings is you can get a larger rotor with out taking a weight penalty.
- It may help keep your wheel bearings cooler.
My opinion:
2 piece floating (pinned) rotor is worth every penny. This is good technology, yeah they cost a ton but they do the job. They keep the rotor even through out operating temperature range and they keep down DTV problems better than anything I've ever seen. Be sure they're the pinned hat type and not the bolted hat type.
Old 01-17-2003, 01:28 PM
romabimmer's Avatar
Lightbulb Warped Rotors
Warped Rotors
Note: DTV stands for disk thickness variation, caused by uneven rotor wear and/or pad material deposited on the rotor. Pad deposit usually happens when brakes are hot and you let them "sit cool"; you should drive around at slow speeds while your brakes cool.
Warped Rotor:
Cut an imaginary plane through the center of the disc part of the rotor that is parallel to both surfaces of the disc, this is done when rotor is new.
If the rotor is warped this imaginary plane (now part of the disc) will no longer be parallel to a reference plane, that reference plane was also parallel to both surfaces of the disc when the disc was new.
In essence a warped rotor is a rotor that is deformed throughout its thickness.
A rotor with DTV (surface imperfection) issues:
The imaginary plane above is still parallel to the reference plane mentioned in the warped rotor definition, however the two surfaces of the disc are no longer parallel to each other.
Think of 2 identical planks of wood.
1st plank you take a planer to it in a haphazard way to the surface making the surface wavy. This is a surface condition.
You can sand the surface down to get back to a smooth surface.
2nd plank you steam heat and then bend around a steel pipe. This plank is warped. You can sand all you want, but you'll never get it straight again.
You can see why it's so easy to mistake one for the other; on the surface it all looks "warped"
Of course if the rotor is too thin then it can't be "sanded" smooth, but a warped rotor can't be turned no matter how thick it is.
Lug Nut Torque
Over-torque of wheel lug nuts is one of the prime causes of brake rotor distortion. This can lead to permanent warping of the rotors, uneven wear of the rotors and pads and lots of brake chatter (NVH).
With today's very stiff alloy wheels, like from BBS, SSR, Volk, etc., when you torque down the lug nuts the wheel-mounting surface will force what ever it contacts to take its shape. Which means whatever that surface looks like will be what the rotor looks like.
Get a torque wrench and check the torques on every lug nut and make sure they are within the specs (which you should be able to find in your owner's manual). And make sure that every lug nut is torqued down exactly the same. Even if all 5 on a wheel are within specs, not having all 5 be equal will introduce distortion.
And if you think that your light alloy wheel can't possibly be that stiff, you wrong they are MUCH stiffer than the brake rotor or even the hub.
WORD OF CAUTION: Don't assume that torque the lugs to the lowest range in the spec is the best. Try and keep it nominal not at the extremes of the range.
Much of the problems with rotor warp, brake chatter, disk thickness variation can be traced back to over-torque and uneven torqued lug nuts.
After coming back from the shop, get that torque wrench and check the lug nuts yourself.
2006 Ody: Vehicle / braking shudder matt1037 Odyssey 2 06-01-2010 11:56 AM
A "Goodbye" present.(Very very long) 90Stangjc Stress Release 20 09-20-2004 11:16 PM
Vehicle Brake Information (very long) romabimmer General Discussion 0 11-24-2002 07:26 AM
