Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-16-2007, 11:18 AM
johershey johershey is offline
Angry Camshaft Sensor code
i have a 1995 bonneville it has been stalling out lately at low rpm and tryies dying on the highway to if you don't keep the rpm's up but it getting a Intermiitent signal from the camshaft sensor. so i repaced the sensor and worked great for a week. now it's coming up with te same camshaft sensor code ad stalling out again. i've cleaned the battery terminals (they weren't bad at all ) and i'e replaced the IAC by recomendatin from a mehanic. if anyon could help i would appreciate it thanks
Old 09-16-2007, 08:43 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Camshaft Sensor code
I assume that you are getting a code 41. This code can be either the cam or crankshaft sensor. You have replaced one, so guess what is next?
Old 09-17-2007, 06:15 AM
jdq jdq is offline
You said you changed the sensor, did you check if the magnet was there.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 09-17-2007, 08:00 AM
yes i did scheck to see if the magnet was there the old one came out in one piece. so i guess i'll change the crankshaft sensor if your telling me the code is the same one.
Old 09-18-2007, 11:04 AM
jdq jdq is offline
I would also assume crank sensor then.
Old 11-17-2007, 08:00 PM
fuelmaxman fuelmaxman is offline
yeah, the cps will act up more oftenly when the engine is warm, therefore you can pin point it a little bit more easily, but that would by my guess as well. it's the sensor that intersects the interruptor ring on the harmonic balancer(bottom pulley) good luck
