Go Back   Automotive Forums Car Chat > Chrysler > Pacifica
Old 09-16-2007, 09:26 AM
badgerdoc badgerdoc is offline
Stalling Pacifica
My 2004 AWD has taken to stalling when I start it--it starts readily but then immediately stalls. Happens repeatedly--always starts easily and runs fine with the accelerator pressed, but when I let off the accelerator and the RPMs slow toward idle, it stalls. Then, other times, it runs perfectly. The problem seems to run in streaks--some days it happens every time I drive, other times it won't happen for a couple of weeks. I have had a friend put a code reader on the car and no codes are being stored. I am stumped. Any thoughts or suggestions would be appreciated.
Thanks.
Old 09-16-2007, 10:07 AM
taillight taillight is offline
Re: Stalling Pacifica
Try cleaning the throttle body, throttle plate(backside) and IAC.
Old 10-06-2007, 12:31 AM
danauto danauto is offline
check the throttal position sensor if cleaning the t.plates don't do any good. wiggle the connector it might give you a sign
