Old 09-15-2007, 11:02 PM
nalgman's Avatar
nalgman nalgman is offline
chamshaft question
hello there..
i want to install a new camshaft to my blazer 4.3L Z .. if i do this.. the computer will throw me a code or something? or what i can do?
thank you..
Nalgman
Old 09-16-2007, 09:30 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: chamshaft question
Just a guess here.
If the manifold vacuum, engine temperature, ignition timing, fueling & what the O2 sensors input to the computer are within the parameters of what's been programmed, I don't see how there should be a problem.
A torque improving or towing camshaft might improve fuel milage too.
Is this what you have in mind?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 09-18-2007, 01:03 AM
nalgman's Avatar
Originally Posted by Chris Stewart
Just a guess here.
well..
my dad had a lot of 350 parts. i have some reading that the 350 is like the 4.3 but without 2 cylinders.
so all these parts where never used before.
so i wonder if can i install some of this equipment. like a camshaft.
im planning to put some headers too for the v6.
when i bought my 90 blazer, the engine was a piece of crap. so i rebuild the engine and bored to 30. just want to know what i can do with.. without changing my TBI. so the only thing that stops me is the ECM..
thank you!!
Old 09-18-2007, 02:53 AM
DINO55's Avatar
DINO55 DINO55 is offline
well..
thank you!!
350 = 8CYL
4.3 = 6CYL
I don't think you can use anything from a 350 engine on your 4.3
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 09-18-2007, 07:12 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Sorry Bro, a Camshaft for an 8 cylinder won't fit into a 6 cylinder engine. Replacing a camshaft is can be a good thing if it is done right. If you are willing to invest in a good Cam, new Cam bearings, new lifters and you're willing to pull the motor out of the truck to install everything, you'll probably see a huge difference in your performance. If you skimp, you'll probably regret it.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
