Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 09-15-2007, 07:40 PM
20impala04 20impala04 is offline
door panel removal
I have a 91 4 door. I have tried to take off the panel but it seem to be hung up behind the door handle. I don't see any other screws to remove and afriad I will break something if I just pull hard. Am I missing something? Thanks.
Old 09-15-2007, 07:52 PM
denisond3 denisond3 is offline
Re: door panel removal
You have to take the door handle off before the door skin will come off. When you lift up on the handle, as if to open the door, there will be two small plastic inserts visible by looking up at the bottom of the door handle. These keep the door handle from sliding sideways, and coming off of the mechanism. You have to remove the plastic inserts. On my 92 you remove them by pushing the tiny center 'pin' in, until it falls out the far side. Then you can work the plastic inserts back and out - needle nose pliers or tweezers would help. Then you can slide the door handle sideways and it will come out. Sounds hokey, but it works.
