Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-15-2007, 06:11 PM
timguyli timguyli is offline
98 starter install
A friend asked me to put in a starter in his 98 neon.. Just wondering what kind of job it is as I have not seen the car. Thanks for any info!
Old 09-15-2007, 07:40 PM
denisond3 denisond3 is offline
Re: 98 starter install
Its not too bad of a job, but you will probably need to remove a couple of itmes to make it easier. The Neon Service Manual says to take the through bolt from the front motor mount, and tilt the engine a little forward, to be able to take the starter out from below.
Thats not what I did. I removed the battery and its tray, then the radiator fan (or both fans, as our car has a.c.) Then you can reach the starter without so much difficulty. It has two good sized bolts that you reach from the drivers side of the bell housing (once the battery box is out), and it may have another bolt at the other end, I cant recall. The only caution; when reinstalling the new starter, be sure there are no cables/harness pinned between the body of the starter and the front of the engine block. Otherwise it wont seat evenly.
