Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-15-2007, 08:19 AM
Sigma6 Sigma6 is offline
Another timing belt ???
Trying to find parts locally for 97rodeo with3.6l. Exactly what parts for tensioner do I need. Everyone wants to sell me a $200 kit. Is that what I need?????
I also have read that some belts are not marked correctly???
I can find water pump and belt fairly easily.
Thanks for any help.
2007 Chevrolet Silverado
1997 Izuzu Rodeo LS 4WD
Old 09-15-2007, 01:54 PM
Ramblin Fever Ramblin Fever is offline
Re: Another timing belt ???
Just so you know, I'm sure you do, probably just a typing error on your part; but, your Rodeo is a 3.2L, not a 3.6L.
I purchased my timing belt package through the dealer; it does cost more, but at least I know I got 100% Isuzu OEM parts. I use Isuzu parts for everything engine related on this truck.
Others have used timing belts that were not actual Isuzu belts and have had timing problems until they've switched to an Isuzu belt; something to do with the alignment marks on the belt - but don't quote me 100% on that.
You need to do *at minimum* timing belt, timing belt tensioner, and waterpump.
I have a '97 Rodeo too, but I included other items in addition to the above; i.e idler pulley, some other kind of pulley (can't remember, sorry)camshaft/crankshaft seals (mainly due to their age, and you're already there), hard to reach coolant hoses (at 10yrs of age, they're shot, trust me), coolant flush & take a good look at your radiator, if it's original and you're over 120k, it's probably about shot.
Also, if you haven't already make SURE to do the heater core hoses on the passanger fire wall; trust me, they are long past shot if they're original, and when they blow, they blow BIG and are HARD to find hoses. There's 2 of them, dealer or Napa only and expect to pay about $120> for both.
Also, you might as well replace all 3 of your driving belts, have to take them off anyways, and if they have 25k+ miles might as well.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 09-15-2007, 02:16 PM
trooperbc's Avatar
trooperbc trooperbc is offline
what ramblin 's telling you -- since you need to do the timing belt, you might as well rebuild the engine while you're at it
i agree on the minimum stuff, and i agree on oem over ebay and other sources and on the extra pulleys they put in those kits, i suspect your origninal is better used than those are new...and you will want to replace those pulleys *if* an inspection shows they need replacing (bearings). others have had seal problems, so give that a consideration.
those 'kits' btw usually don't actually include the tensioner, which is absolutely necessary.
while some of the other stuff might need attention, i don't think you gain anything from doing them when you do the belt.
if your isuzu dealer is umpteen miles away, consider using a dealer in missouri who gives interenet discount, free shipping to your door, expert parts guy ask for MERLIN
http://isuzu.stcharlesauto.com/Department-Parts.aspx
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 09-15-2007, 03:33 PM
Thamks guys. I think I will call St Charles Isuzu on Monday. I definetly need to get this done. It is making a lot of noise when cold. After this I am going to tackle half shafts.
Old 09-15-2007, 06:14 PM
trooperbc's Avatar
WOW !!! hold on der....
what you mean " It is making a lot of noise when cold. ""
the new timing belt and tensioner, etc. isn't going to solve that -- if you mean the valve ticking noise. please clarify what the noise is.
//bc
Old 09-16-2007, 08:47 AM
It is a LITTLE noisy, partially because of squeaky altenator belt. I have read that these need to be pretty tight. I have heard other Rodeos, they all seem to be a little noisy.
Old 09-16-2007, 11:59 AM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Could also be a 2.6L.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 09-16-2007, 04:35 PM
And yes, I have the 3.3L
Old 09-16-2007, 05:05 PM
Cat Fuzz Cat Fuzz is offline
I really don't see the need for the replacing of every part under the timing cover. I've done a lot of timing belts and the 3.2L Isuzu is one of the easiest to do. Takes me about 40 minutes without hurrying. What I do is give each pulley or idler a spin and if it spins fast and takes a while to stop, it gets replaced. Wiggle the water pump shaft, look for leaks near the weep hole, if no play or evidence of leaks, it's still good.
Old 09-16-2007, 06:00 PM
I think the difference is in the way the trucks are used, my rodeo would be considered under severe service. Most items probably didn't need changed, but I VERY frequently find myself hundreds of miles from no-where and require a very dependable vehicle, and I hate having a vacation interrupted by a major expense should some $5 part break that was in the same area as the other items I had just replaced.
Also, I am VERY paranoid about overheating conditions, thus keep watchful eye on my coolant hoses, cause these are all aluminum engines, and I've had to endure the horrible expense of replacing a toyota engine simply because I didn't *think* 9-10yrs of age required replacing hoses that *looked* ok.
However, 95% of the world has better luck then I, so I would just do the pump, belt and tensioner.
Your cold weather tapping could be do to oil thickening overnight and taking a few seconds longer to reach top of engine.
The above is depending on whether you have the 3.2L V6, if you have the 2.6L, I know nothing of that engine.
1997 3.2L V6 Rodeo
Old 09-17-2007, 02:46 PM
Ok guys, I ordered the tensioner and timing belt from St Charles. I guess I have to do this now. I just need a water pump and a case of beer, both found locally. Breaker bar against frame technique will be used. And should I rent a puller??
Old 09-17-2007, 11:00 PM
FL 3.2L FL 3.2L is offline
I didn't need one for my FL truck.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 09-17-2007, 11:45 PM
trooperbc's Avatar
i absolutely needed one for my 1992 trooper -- you can get a fairly good one from harbor freight btw.
others have absolutely *not* need one.
just don't go banging and excessive prying on that harmonic balancer.
btw -- why didn't you buy the oem water pump?
//bc
Old 09-19-2007, 10:34 AM
tony4x4nc tony4x4nc is offline
Smart move going with the OEM.....I bought a kit off ebay including tensioner $215. Ended putting it on 3 times without timing being right because it only had 2 marks instead of 3. Also still had my knocking with the non OEM tensioner. Bought a new belt and tensioner from the dealer pt it on in 30 min and all problems gone. I also rented a pulley puller from Autozone to get my harmonic balancer off. Not trying to rob the thread but did anyone check to see what, if any, cylinders were at TDC when they did this job. I just lined the marks up popped the old one off and the new one on never checking for TDC on any cylinder.
Old 09-20-2007, 05:57 PM
oem water pump was pretty expensive. I may check out harbor freight for puller. We have one locally.
