Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 09-15-2007, 12:09 AM
Chad82 Chad82 is offline
Send a message via AIM to Chad82
Old Man Emu?
I tried searching on it, but it wouldn't find any results since each word is only 3 letters. If it matters, I have an 01 SR5 4x4.
Does anyone have any experience with their suspension set up? Today I did the "bounce" test and it got about 3 rebounds before stopping. Add in the rough ride, I figure its about time to freshen it up. After some cursory research, it looks like OME is a pretty good set up for a reasonable price. But I was wondering how their "medium" vs. "heavy" duty set up compares. This is my daily driver but I want to do some off-roading but nothing too serious. Would the medium suffice for that or would heavy be better? I want to do a mix between streetable and good enough for trails/mild off-roading. I do no towing, but might in the future. Also how hard is it for an average Joe to replace the suspension? Is there anywhere that you can like rent a coil spring compressor? Certainly isn't something I own and due to the pressure I assume I don't want to just wing it with stuff I have around the shop. And is there anything else you need to replace to keep handling and the like reasonable?
Also relatively new to the 4wheeling side of things (was mostly using friends rides, unfortunately I have lost contact with most of them over the years, so far I have only done easy trail runs for fishing and a bit of messing around), but I assume that if I get bigger wheels/tires, I might want to increase my braking since it would be increasing rotational mass? This would also help for future towing. I assume a rear-disc conversion is the easiest on this. Once again, uncharted territory for me, but this looks reasonably easy. It looks like some 80s GM vehicles are pretty easy replacements, but anyone have any experience with it?
Also if anyone has experience with the OME for this generation, what size tires have you been able to fit under your 4runner? Its a 2-2.5" lift.
Old 09-15-2007, 12:37 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Old Man Emu?
Put the search in quotes "Old Man EMU"
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-17-2007, 08:09 PM
Re: Old Man Emu?
did it in quotes and it still didn't work. Did a google search on AF and the results didn't seem to answer the questions I asked.
Old 09-17-2007, 08:33 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Old Man Emu?
OK, a few OME observations.
Their stuff is great, a few years back I put an OME susp on a friends 94 Trooper, it rode and handled better than my brand new 2001 Trooper.
An avg Joe that has mechanical skills and tools could do it.
A spring compr is needed, and can be borrowed fro most parts stores.
You will need to have a front end alignment right away (if you do front t-bars).
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
