Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-14-2007, 08:40 PM
Nick Dubya Nick Dubya is offline
Send a message via AIM to Nick Dubya
1989 5spd trans
Me and my buddies are converting my auto into stick and we are having trouble removing the driveshaft
we removed the 4 bolts in the rear towards the differential, and the bolts up front, and we lowered the trans and it wont slide out from the front or back
any help would be appreciated
any help ASAP would be greatly appreciated
=Dubya
Old 09-15-2007, 02:22 PM
Morley Morley is offline
Re: 1989 driveshaft
Gotta slide it forward till the rear drops out of the pinion shaft, then slide it aft to get the tailshaft out of the transmission. Use a large screwdriver to pry forward between the U joint and pinion shaft.
Old 09-17-2007, 11:52 PM
Re: 1989 driveshaft
okay, the driveshaft is out.
now, idk if its supposed to be like this, but...
it looks like the bellhousings is slanted to the left, and that means the trans will sit like that, and im not sure at what length i should cut the hole at the center console floor
