Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-14-2007, 05:39 PM
darkvamp darkvamp is offline
Unhappy always push start
hey there well i have a 95 eclipse gst and cant started unless its push started or if i turn the ket repidly to start it the starter altinater batt and batt connections have bin replaced and still cant figure it out it would work fine for a day or so then go back to not starting need help
Old 09-14-2007, 06:39 PM
MazdaX's Avatar
MazdaX MazdaX is offline
Re: always push start
Sounds like you have either an electrical leak ( something constantly draining power non stop until dead ) or you ignition switch maybe no good ? who knows..need more info.
2004 Mazda 6i
1997 Tahoe
Old 09-14-2007, 10:23 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
If it turns over, then there should be nothing wrong with the ignition or any electrical "leaks" or malfuntioning. If it just cranks and cranks before finally firing up, thats a sign of a bad fuel pump. Please give us a little more description of the problem and we can give you a better answer.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-17-2007, 09:50 AM
bleedEGLblue's Avatar
bleedEGLblue bleedEGLblue is offline
I had this same problem with my last car, 94 Talon, about a year ago. I cant narrow it down to a T for you but these are the things that i changed to solve the problem. Everyone insisted it was the TPS sensor but not having the cash to buy one I beat around the bush and mess around with some cheaper stuff. I changed the temp sensor and the barometric pressure sensor and the problem magically disappeared. (one of the characteristics of my problem was that if it was cold out there was no hope at all.) So, my best guess is that since the pressure sensor and the temp sensor both regulate starting that the sensors were sending faulty cold or hot start signals, or faulty air pressure signals. If not it may be the TPS.
Live From The Great State of Hockey
93 Eagle Talon Tsi
Rebuild TTD:
Ross Racing Pistons(.20 over) - comp 101200's - Head Rebuild Kit - Port/Polish - Big 16g ported Internal WG 34mm - DNP Tubular Exhaust Mani - Megan Racing O2/Outlet - Apexi DP - Walbro 255 - 660cc's - Venom FR - JDM FMIC - Link - Apex'i timer - Short Throw - OEM TB - -6 Fuel Line - FPR - Water/Meth Injection - GM MAF
Previous Mods: GReddy type-rs BOV, 2.5" exhaust, ED Drifter BodyKit, Python security
