Old 09-14-2007, 02:32 PM
samahi72 samahi72 is offline
95 Blazer Is there a trick to replace the tranny filter?
Trying to replace the fluid and filter in my 95 4 wd automatic. I took the bolts out but I can't get the pan to drop. The exhaust cross over is in the way. I took out the tranny crossmember but it still wouldn't drop because of the exhause cross over. I do not want to unloosen the exhaust because my experience is that the exhaust bolt will break in the manifold and I definitely do not want to mess with that. Anybody have any special tricks that they have used? Thanks
Old 09-14-2007, 04:53 PM
silverblazer silverblazer is offline
Re: 95 Blazer Is there a trick to replace the tranny filter?
I found that it only comes out so far. You can still change the filter with that min space.
1995 Chevrolet Blazer LT
4x4 Red and Silver
CHEVYS RULE
Old 09-14-2007, 06:47 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
With the crossmember off, put a jack under the transfer case(most likley there already) and jack up the transfer case as much as it will go. That will open the space between the exhaust crossover and give you the rrom to pull it out. Its a little tricky, but it will come out.
Old 09-27-2007, 08:58 AM
Definitely one of GM's engineering oversights. If you have to pull the crossmember out, jack up the engine just to get enough space to drop the pan what an oversight that was.
