Old 09-14-2007, 12:39 AM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
Any POWER CURVE (rpm vs torque) published for the 3 cylinder Suzuki engine?
The title says it all....the one in my '93 Metro?
Just wondering what gear and rpm to use going up a hill with a heavy load.
DoctorBill
Old 09-15-2007, 08:47 AM
GM Line Rat GM Line Rat is offline
Re: Any POWER CURVE (rpm vs torque) published for the 3 cylinder Suzuki engine?
Your really dealing with a "Limited" amount of Torque / Range in these engines and transmissions Doc. I too have to deal with the occasional hills in my area...25- 30MPH.....3RD Gear. At 40...4TH Gear etc..
91-94 Geo Metro engine specs:
Powertrain Options and Availability
All Metros used a 1.0-liter, overhead-cam 3-cylinder engine. Rated 52 or 55 horsepower in standard form, it developed just 49 horses when installed in the frugal XFi Metro. A 5-speed manual transmission was standard; 3-speed automatic available on base and LSi versions (but not XFi).
Engines Size : liters ohc I3 1.0 / 61 CUI
Horsepower: 52-55
Torque : 56-58 ft lbs
Fuel Capacity : gals. 10.6
Fuel Mileage : 5-speed manual: 46/49 3-speed automatic: 36/39
Old 09-15-2007, 09:45 AM
DOCTORBILL's Avatar
Geo Metro Lover
Someone or some organization must have put this engine on a dynamometer and
measured the power output vs rpm....like this:
http://www.germancarzone.com/3-serie...vs-m5-v10.html
http://www.epi-eng.com/ET-Eng-Gen-1.htm
Isn't it a rather "famous" Suzuki engine - used in motorcycles originally?
DoctorBill
Old 09-17-2007, 10:01 AM
DoctorBill
I've heard that they used these engines in small planes Doc....But not in motorcycles that I'm aware of? Most Suzuki bike engies are 4 Cyl. Given that the engine makes a peak HP of 52-55 horses, I'd say the only one to put it on a dyno would be Suzuki or GM during the research and development phases of the engines.
Old 09-17-2007, 02:19 PM
Mike_Van Mike_Van is offline
It's one of the few gas engines that I've seen that has a (marginally) higher torque value than horsepower value.
Usually that relationship is inverse for gassers (hp > torque).
1999.5 Golf 1.9 l TDI, 5 spd., 154k mi., Panzer Plate, B20, FrostHeater
2007 Passat 2.0 l TFSI, Auto, 83k mi.
