Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-13-2007, 05:04 PM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
Glow Guage Backrounds
I just bought some aftermarket blue glow backrounds for the dash and if i plug them into anything but my car, they work, but when i wire them up to my car they wont glow! It has been so frustrating, i have tried splicing them into the stock dimmer switch, didnt work..... i tried running them to a hot switch, didnt work..... i know they are connected correctly and i know they work properly, but it makes no sence..... Any ideas?
97' Eclipse RS 5 Speed 420A
Under The Hood:
Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires
Interior:
Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout
*GOAL* - Prove Him Wrong
Originally Posted by UnderEstimate Me
I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs.
Old 09-13-2007, 06:21 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: Glow Guage Backrounds
Did you turn your lights on with them wired up? I know it sounds like a stupid question but you would be suprise.
If the answer is yes, do your normal guage lights work?
And are you sure you have the power and ground correct? You can't always go by the wiring on the guage to match up to the car. As sometimes the wiring colors mean different things from different cars.
1991 GSX 2.3 Stroker
Old 09-13-2007, 07:02 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
If the gauges work when you hook power to them then they proabably aren't getting power. When you hook them up use a volt meter to make sure they are getting 12v.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
yea, i checked it all and i hooked something else up to it instead of the guage backrounds, and it worked..... i really dont know wtf is wrong, but its really pissing me off, and i also did have the lights on. I really dont know whats up with it..... by the way, yea the stock ones still glow.
Under The Hood:
Interior:
Old 09-13-2007, 07:04 PM
Holset powered 420a
Make sure you have a good ground. I have had problems like this before with other things I have wired. Some times just touching the wire to a bolt doesn't work.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-14-2007, 10:34 AM
defiancy's Avatar
Yeah, if you have access to a voltmeter can you shoot the wires real quick and make sure you have power and continuity?
If you need me to elaborate I can.
Old 09-14-2007, 03:31 PM
it was stupid. They snt it with a switch not saying you had to have the switch connected and crap like that. Its really messed up but i had to have the switch connected and have it grounded, which they also didnt tell me.....make a long story short, i figured it out on my own after being creative and with no help from the manufacturer..... they look pretty sweet tho, lol
Under The Hood:
Interior:
Old 09-14-2007, 04:08 PM
defiancy's Avatar
Glad you got it figured out then.
