Old 09-13-2007, 03:58 PM
jslattery_50 jslattery_50 is offline
99' interior fuse cover
I'm missing the fuse cover from the inside fuse box that has what all of the fuses are and what they do. Could someone tell me which fuse number is for the right hand power window?
Old 09-14-2007, 12:48 AM
catvents catvents is offline
Re: 99' interior fuse cover
THe following is for a 2001 model; could be similar but not 100 % sure. Fuse number 18, control the radio, power windows (both side) and Instrument illumination. If the radio is correct, the power window should work.
This fuse is a 15A. and is located on the first row of the left side of the box, and the fuse is the 4 th from the top. The power window motor is feed through the Front Electronic Module (FEM) and also through the Accessory delay relay which is located in the fuse box. But if one side is working I would suspect the right window motor or the switch. By the way try the left and right switch (if it's not ever done). And do not forget I'm talking about an 2001 model.
Old 09-14-2007, 06:24 AM
12Ounce 12Ounce is offline
Look under "roadside emergensies":
http://www.motorcraftservice.com/pub.../99winog1e.pdf
