KIA Sportage – sputtering - misfire - no power - check engine – smoke - PO303
My Sportage was having problems After searching Sportage internet sites, I saw many others had a similar problem I put a check list of possibilities together for you Print This Out and Take It to Your Mechanic SYMPTOMS Engine Not overheating Check engine light is flashing car sputters has no power if driven for a time white/gray smoke comes out tail if driven for a time muffler becomes SUPER hot may or may not code PO303 - Cylinder 3 misfire detected Have Your Mechanic Check These: harness wire to coils (kinda hidden in back) – this is what fixed my Kia coils leads timing timing belt tension muffler o2 sensor fuel filter spark plugs CSP sensor rust in lines MAF sensor vacuum leak throttle sensor leaking gasket mass air flow ignition timing cadillac converter Idle control valve injectors flooding crank position sensor injection flush may fix it spring missing on cylinder 3 No ground at injectors 1 and 3 exhaust gas recirculation valve sticking injector comes and goes 2 wires skinned or repaired with tape gap the new spark plugs they don't come pre-gaped coolant leaking into the cylinder - coolant covering the piston Bosch +4 plugs cause the engine to misfire - Go the original spec NGK plugs are really fouled like an injector leaking down - then flow test is bad Last edited by HPYUNBDAY; 05-23-2009 at 09:09 PM. |
Re: KIA Sportage – sputtering - misfire - no power - check engine – smoke - PO303
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
