Help!!
1995 Ford Probe, 2.0L--replaced blown head gasket, replaced lifters--car will crank but not start--has spark, compression and fuel. no codes--
don't understand why it won't start--any suggestions?
Re: Help!!
Squirt a little carb cleaner in the intake and see if it will fire.
Re: Help!!
already did that--it backfires
Re: Help!!
When you removed the head did you have to remove the valve timing belt ? Maybe the marks were not lined up after.
Re: Help!!
timing marks are correct per ONDEMAND instructions, as is the firing order
Re: Help!!
180 out maybe?
Re: Help!!
Distributor 180 out. Pull #1 spark plug. put #1 cylinder at tdc compression stroke(both valves closed). Is distributor pointing at #1 plug ?
