Old 09-12-2007, 04:11 PM
Renelsisc Renelsisc is offline
I messed up....glue on window..please help...
Hi guys,
So on the FINAL step of my project Supra, I had to glue the rear view mirror on the window. Of course, i HAD to drop the tweezer when placing it and there's a small patch of glue on the window now. It looks sorta like it's scratched/fogged up. Any way of removing this? I am such an idiot.
Thanks
Old 09-12-2007, 04:36 PM
klutz_100's Avatar
Re: I messed up....glue on window..please help...
What kind of glue where you using?
Old 09-12-2007, 05:58 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
...and why (oh why) don't people include this kind of info in their initial question????
PHOTOBUCKET SUCKS
Old 09-12-2007, 06:15 PM
rallymaster's Avatar
Hello,
I was the glue-accident specialist on my first models !
So here is what I do when I have some glue-haze or worse a drop of glue falling on the window.
First thing, I let it dry several hours (not to spread it more when trying something)
Secondly, I sand the drop of glue (but not with rough sandpaper, be carefull not to sand to much) and sometimes scrape it with a tooth-stick before sanding.
And to find back the translucide, I use compound... again and again till getting a satisfying result.
You can also try to "wash" the window with isopropyl alcohol, that doesn't hurt translucide plastic, but you'll need to use compound anyway I guess...
Hope it can help.
Phil
Old 09-12-2007, 10:20 PM
i am so sorry, forget to mention glue type...i'm a newb...anyway, i was using drips of Testors clear cement thingy and just dip a SMALL portion using a toothpick...thanks
Old 09-12-2007, 11:16 PM
klutz_100's Avatar
As Phil says, sand down and then polish back up to clear.
You will find useful information here: cleaning and replacing clear parts
Old 09-12-2007, 11:33 PM
Joe Blyth's Avatar
Joe Blyth Joe Blyth is offline
Isn't Testors clear cement water-soluble? I'd try wiping it off with a wet q-tip before sanding it down.
