Old 09-12-2007, 12:58 PM
jonesrsrg jonesrsrg is offline
1991 pontiac grand prix tranny help needed
im having problems with my grand prixies transmission. the car has 100000 miles on it. a 3.1 litre motor.i just chnged the filter and tranny fluid a few days ago. after i chnged it i drove it about 60 miles when it wouldnt shift into drive or over drive. when it does go into drive it seems like it is in neutral. i had it scanned and no codes came up . it will will shift from low to second ok .i checked the tranny fluid it doesnt smell burnt and the level is ok.any help to steer me in the right direction would be greatly appreciated.
Old 09-12-2007, 01:04 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 1991 pontiac grand prix tranny help needed
Welcome to AF!
Are you checking the level after the car has warmed up, on level ground, in park? Were there any trans problems before you did the fluid/filter swap? Finally, you didn't do a trans flush/fluid exchange did you ?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-12-2007, 02:40 PM
yes i checked it in park and on level ground, fluid checked ok. no i didnt do or ever have done a trannyflush. i just changed oil and filter. the tranny shifted ok thru all gears . Im checking out the electrical conector on the side of the tranny for the shift selinoids. can any one tell me wht wires i need to ohm for each solenoid? the letters on the connector are a,b,e,c and d id also like to thank u all for having a great info site and a ty for the quick response
Old 09-14-2007, 06:03 AM
richtazz's Avatar
Have you tried shifting it manually into drive or od, and if so, does it go then?
If it will shift manually, you may have a bad modulator valve or vacuum issue to it.
Old 09-14-2007, 05:28 PM
yes ive tried shifting manualy it still doesnt work . ive tested the modulator and it is good.
