| Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines. |
96 Maxima w/ code p0745
I recently bought a 96 maxima and it has a problem with the auto transmission when shifting from 1st to 2nd it creates a shock under normal driving conditions, I connected a scanner and found code p0745 line pressure problem, I checked the pressure solenoid for operation and it seems to be working fine also checked connectors for any signs of problems but looks good, i also checked the schematic for the solenoid and it seems to be routed to a drop resistor located on the d/s strut tower..Can this resistor actually be the problem?? Has anyone ever experienced this problem??
Help will be greatly appreciated,Thanks |
Re: 96 Maxima w/ code p0745
The upshift change rpm treshold is moved up/down using that R/switch ... cant see how it could affect...
My non educated guess would be line pressure drop (sieve blocked?) or valve problem. Check links from this page: http://www.cardomain.com/ride/748507/24 |
I just confirmed whats causing my shift problem, when my girlfriend came back from work i quickly transfered over the drop resistor (same p/n) and transmission shifted like normal again so now i know what i need to buy...
Thanks for the help. |
BTW the car that i used the part from is an 03 Nissan Altima 3.5l a/t.I beleive theres a couple nissans using that drop resistor.
