Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-11-2007, 11:37 PM
mtcs's Avatar
mtcs mtcs is offline
Send a message via AIM to mtcs Send a message via MSN to mtcs
Injector difference HELP!
I used to have a GT3076R with FIC 850cc injectors. Those injectors were perfect for that turbo. I have currently upgrading for a PTE 6152SP, SBR FMIC, SBR exhaust manifold, new 02 housing, and downpipe. I was told that if I stay with the 850cc injectors then I will not be able to run my turbo to its full capacity. I was thinking of upgrading to some 1000cc injectors. Can anyone enlighten me on the difference 1000cc injectors would do compared to my current 850s....Is it worth changing them?
Thanks
1996 ECLIPSE GST
2.3 Storker, 6 bolt, XACT flywheel, ACT Clutch, B&M shifter, DC SPORT Carbon steel strut tower bars, EVO2 exhaust, 1000cc injectors,Aeromoive rail, MBC boost controller, PTE 6152SP, SBR exhaust manifold, TIAL BOV, SBR FMIC, TEIN SS, Walbro fuel pump, AEM EMS, AEM UEGO, FP turbo intake, Aeromotive FPR, Magnus intake, 62mm throttlebody, Stoptech big brake kit, brembo rear slotted discs, Stage 2 Shep transmission (quafe), sparco fighter seats, sparco harnesses
Old 09-11-2007, 11:56 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Injector difference HELP!
Might want to go ahead and put some bigger ones in there just to be safe. You have dsmlink so might as well go big on the injectors and not have to worry about them ever again. You dont want your injectors to limiting factor to your power output.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-12-2007, 12:14 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Well, if you are going to run out of fuel with the 850's then you kinda have to upgrade and there are charts around that can tell you what airflow numbers a certain injector size will allow for. Remember, you want to keep IDC's below 85% if at all possible. If the 1000's are too small, FIC makes 1150's and 1600's as well. I would venture a guess that the 1000's should be fine, but if not then if it were me, I would just jump to the 1600's.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-12-2007, 12:20 AM
kjewer1 kjewer1 is offline
AF - Advisor
I can't keep up with these friggin turbos names that keep multiplying by the day, but I'm assuming that's the wheel from the GT3582, and in that case, 950s are much more appropriate. 850s will limit you to about 60 lbs/min.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-12-2007, 03:01 PM
mtcs's Avatar
If i go above 1000cc injectors, won't i have to be running EMS? DSMlink doesnt do well above 1000cc injectors or so I was reading....
1996 ECLIPSE GST
Old 09-12-2007, 06:13 PM
Thor06's Avatar
Jizzed In My Pants
I have heard of people having a tough time with 1600's but at the same time I have heard of people being just fine with them. Any idea how much air the turbo flows?
